brake disc wobbles back and forth on both sides help!
took off my wheel because it was wobbling. the rotor is wobbleing too on both sides, but the rihght side wobbles the most!
what could be the problem?
Re: brake disc wobbles back and forth on both sides help! (mr. teal Type R)
are the holding screws in them?? were your lug nuts loose??
if the screws arent in place and the wheel is off they will wobble.
the wheel only wobbles if it is bent or the lug nuts are loose.
Re: brake disc wobbles back and forth on both sides help! (civictildeath)
well I have removed the rotor. It seems to be that the axle nut wasnt tight enough, but I tighted it to 120 ft lbs and it didnt solve the problem. So I took it off. My guess is that the hubs are worn out from being too old. The could also prolly use new bearings..
who knows maybe I'll be able to get some type r front knuckles and suspention
Re: (vtekstorm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm »</TD></TR><TR><TD CLASS="quote">sounds like your hub bearing took a **** cuz the axles werent in all the way. </TD></TR></TABLE>
i dunno...i put them in as far as I could
Re: (mr. teal Type R)
u might have put them in all the way but if the threads on the axle are stripped u gonna have problems cuz they werent on tight
