preloading
Old Dec 14, 2005 | 06:03 AM
wpgcivic's Avatar
Default preloading
ok in the past ive had bad experiances at the track my snapping axles inside of my tranny thus ending my racing day...
for preloading the clutch, when staged pull the ebrake gas and let out the clutch a little?
just wondering, ive always ran 2 step will lets say 4500 be too high to preload? if so what is a good rpm to preload at?
thanks, sean
Old Dec 14, 2005 | 06:33 AM
nsxmatt's Avatar
Default Re: preloading (wpgcivic)
I preload at 8300rpm and slip a little. Never a broken axle and 1.6 60ft times. I don't use a 2-step though.
Old Dec 14, 2005 | 06:55 AM
smokey2.0's Avatar
Default Re: preloading (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">I preload at 8300rpm and slip a little. Never a broken axle and 1.6 60ft times. I don't use a 2-step though.</TD></TR></TABLE>so how do you hold 8300rpms? rev limiter?
Old Dec 14, 2005 | 07:04 AM
nsxmatt's Avatar
Default Re: preloading (smokey2.0)
I don't hold it, I blip the throttle and it bounces off the limiter slightly which is at 8300.
Old Dec 14, 2005 | 07:09 AM
wpgcivic's Avatar
ok so with the engine revving that high wont it push the car forward a little bit? is it a good idea to stage early not deep incase of this?
Old Dec 14, 2005 | 07:17 AM
nsxmatt's Avatar
Default Re: (wpgcivic)
Don't let out the clutch as much, you can feel when it starts to touch and just leave it there. As the light turns let out and the car will start to move slightly, then let it out completely. I do it without the e-brake even without rolling through the lights.
Old Dec 14, 2005 | 07:34 AM
wpgcivic's Avatar
holy **** are you serious dont even use the ebrake? i thought that was the only thing holding back...well ill take my stock z6 out soon and try this out
thanks for the help, it'll take a lot of practice but i eventually have to get used to it, what axles are you running, i am just worried because this is with a d series and i really dont feel like dishing out a grand for axles
Old Dec 14, 2005 | 07:47 AM
93H22ACX's Avatar
7500rpm launch with a 2 step.
i dont use my ebrake.. i just let the clutch out as high as possible without the car moving and drop it from there.
both our cars use autozone axles
Old Dec 14, 2005 | 08:02 AM
beerbongskickass's Avatar
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Don't let out the clutch as much, you can feel when it starts to touch and just leave it there. As the light turns let out and the car will start to move slightly, then let it out completely. I do it without the e-brake even without rolling through the lights.</TD></TR></TABLE>
Exactly how I do it and I haven't broken any axles either (except I am at 7300 rpms).
I think if I tried using the e-brake I would just *** my launch up lol...
Old Dec 14, 2005 | 08:04 AM
tony1's Avatar
Default Re: (beerbongskickass)
I do it with the e brake, you really can't load it much otherwise. If you watch the videos of me in the teg, you can see the rear of the car squat on the line from being loaded.
Old Dec 14, 2005 | 08:08 AM
Default Re: (tony1)
Yeah I haven't been to the track in a while, but I have kinda tried it with the e-brake a little bit on the street. I'm sure with some practice I'll get used to it.
If I search for archived posts with your name can I find these videos? I want to see this squat you speak of. ::searching now::
Old Dec 14, 2005 | 08:10 AM
93H22ACX's Avatar
Link of Tony Racing
Old Dec 14, 2005 | 08:13 AM
Default Re: (93H22ACX)
Thanks! Yeah I found a bunch of pivs/videos of cars that Tony has tuned, but didn't find any of his car. I did only search for about 5 minutes though.
Old Dec 14, 2005 | 08:28 AM
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I do it with the e brake, you really can't load it much otherwise. If you watch the videos of me in the teg, you can see the rear of the car squat on the line from being loaded.</TD></TR></TABLE>
Just watched that first video and sure enough your car was squating.
Old Dec 14, 2005 | 08:38 AM
wpgcivic's Avatar
awesome stuff, thanks a lot guys, ive been following with tony1 for a long time now and bbka is a legend in the d series world!!
Old Dec 14, 2005 | 09:35 AM
SOHCboost's Avatar
bout 7500 in my sohc with the ebrake so far so good
Old Dec 14, 2005 | 10:09 AM
seen4ever's Avatar
Default Re: (SOHCboost)
I used to use nsxmatt's method, but found that i started to snap axles at the hub, so next year i'm going to move to e-brake staging, i know i tried it on my 11.2 run and i took a bit getting used to with the rear end dropping but not letting the car roll out too much, but next season will be a new method.
Old Dec 14, 2005 | 11:31 AM
714phil's Avatar
Default Re: (tony1)
I use the ebrake also.. like Tony said.. you cant really load it much without the ebrake.
Old Dec 14, 2005 | 03:18 PM
wpgcivic's Avatar
ok so you guys recommend taking out the 2 step all together? you find that preloading the clutch is better than building boost off the line, plus i really want to not break stuff so yeah...
Old Dec 14, 2005 | 04:11 PM
Adam F's Avatar
Default Re: (tony1)
You are so cool
Old Dec 14, 2005 | 04:20 PM
tony1's Avatar
Default Re: (Adam F)
Wait till i get in your car...
Old Dec 14, 2005 | 04:34 PM
714phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok so you guys recommend taking out the 2 step all together? you find that preloading the clutch is better than building boost off the line, plus i really want to not break stuff so yeah...</TD></TR></TABLE>
I use the aem 2 step building about 17psi at the line with the e brake up slipping the clutch (preloading).
Without the 2 step i dont build any boost which makes me bog really badly off the line.
Old Dec 14, 2005 | 08:19 PM
coltboostin's Avatar
I am the same way.
Just let the pedal sit right at the point of engagement, and slowly let out.
I have never broken an axel.
Old Dec 15, 2005 | 08:24 AM
wpgcivic's Avatar
yeah i practiced a bit last night but its completely different from what the track is going to be like sinse i just have a stock z6 now and snow on the road ....cant wait till i try this out!
Old Dec 15, 2005 | 08:46 AM
B18 CYA's Avatar
wow wpgcivic, you are a true ricer.
