pre- loading the clutch?
Old Jul 21, 2004 | 11:13 PM
AllMotorRandy's Avatar
Default pre- loading the clutch?
what does it mean to pre load the clutch? my friend told me about this tecnique and i still dont quite get it? anyone care to enlighten me? thanks
Old Jul 21, 2004 | 11:48 PM
ninesecrx's Avatar
Default Re: pre- loading the clutch? (jdmEGdrag)
When ur at the line, you let the clutch out just to about where it wants to grab. If you keep it here, its hard on the clutch but it puts tension on other parts such as axles and makes the shock a lot less for those parts and helps them not to break.
Old Jul 22, 2004 | 04:33 AM
N2O's Avatar
N2O
Default Re: pre- loading the clutch? (ninesecrx)
If you are running a stock trans and/or alot of power it is real important. There is a lot of slap between the ring and pinion on a stock trans. When you dump the clutch that slap is what will cause you to tear the ring up. I am not saying that it will not happen if you pre-load but it will last a lot longer with pre-loading. Pre loading will also take all the play out of the axles and everything else in the drive line.
Old Jul 22, 2004 | 12:53 PM
ms1motorsports's Avatar
Preloading will also increase your launch consistency and RT's. Just takes practice.
Old Jul 22, 2004 | 08:56 PM
Kwuaymaikrup's Avatar
Default Re: pre- loading the clutch? (jerseykid609)
Anyone had any luck pre-loading the Tilton twin disk? This thing is HARSH.
Old Jul 22, 2004 | 11:13 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">preloading = happy driveline </TD></TR></TABLE>
preloading = sad rear thrust bearing in engine
Old Jul 22, 2004 | 11:19 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: pre- loading the clutch? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">preloading = sad rear thrust bearing in engine </TD></TR></TABLE>
Depends on the cluth you run, but in most cases yes. Also how much end play the crank has.
Old Jul 23, 2004 | 05:02 AM
lugnuts's Avatar
Default Re: pre- loading the clutch? (Arturbo)
you guys must be running the wrong engines then.... I've had the same used 4 piece thrust washers in my motor since the beginning of 2002, also same axles too (edit:changed from tubular to solid, 1 yr+ on each). Biggst problem for me is going to test-n-tunes and domestic guys play tree games trying (uually in vain) to get out first. I end up having to taks the disk out every 2 months and bead-blast the iron out of the copper pads. But I dont run low 9's so I'll shut the hell up
Old Nov 10, 2006 | 01:46 AM
Richard...'s Avatar
Default Re: pre- loading the clutch? (AllMotorRandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy &raquo;</TD></TR><TR><TD CLASS="quote">what does it mean to pre load the clutch? my friend told me about this tecnique and i still dont quite get it? anyone care to enlighten me? thanks</TD></TR></TABLE>
the only pre load you need is from the e-brake! you pull up the e-brake and bring the clutch to the bite point were the car wants to move then depending on what kinder racing your doing would depend on when you dump the e-brake
word of advice you need to practice your clutch control do you do not light up your tires feathering is the name of the game BUT what ever works for you do not be scared to experiment!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2O &raquo;</TD></TR><TR><TD CLASS="quote">If you are running a stock trans and/or alot of power it is real important. There is a lot of slap between the ring and pinion on a stock trans. When you dump the clutch that slap is what will cause you to tear the ring up. I am not saying that it will not happen if you pre-load but it will last a lot longer with pre-loading. Pre loading will also take all the play out of the axles and everything else in the drive line. </TD></TR></TABLE>
could not agree more!
Old Nov 10, 2006 | 03:37 AM
2point2's Avatar
blast from the past..
darkwater_ghost
10
Nov 16, 2008 07:00 PM
eviltwin66six
Apr 6, 2006 01:37 PM
MachAF
Mar 17, 2003 10:24 AM
MachAF
Mar 14, 2003 03:46 PM
2fast4u
Apr 25, 2002 08:36 AM
