piston movement in sleeve
Old Jun 6, 2011 | 03:12 PM
SLIM NOTHING's Avatar
Default piston movement in sleeve
(cp 81mm pistons, manley h beam rods, gsr, acl bearings stock bore with new hone)
so i assembled my block yesterday, and followed jeff evans videos and so on. i have a question about the piston having a lil movment in the sleeve with everything done. it seems to move with the wrist pin a lil both ways. the piston edges do not come in contact with the walls at anytime. any help is great.,
thanks guys
Old Jun 6, 2011 | 03:44 PM
turbo-2nr's Avatar
Default Re: piston movement in sleeve
thats just your piston to wall clearance the cylinders should of been bored/honed to your spec with your pistons
Old Jun 6, 2011 | 04:16 PM
Honda Bull's Avatar
What was your piston-to-wall clearance set at?
Old Jun 6, 2011 | 04:34 PM
oh i just desided and said screw it and send the block to GE or darton and have it sleeved now then later. this is just a test process for me, im learning as i go with things. for some reason im thinking the machine shop mite have done something wrong. everything fit great before i dropped it off for a hone. maybe it was just me making a mistake somewhere but hey you gotta learn some how. like i side ill just get it sleeved. cause i was looking for 600 on stock sleeves on e85, but now ill set that a lil higher if i sleeve it.
Old Jun 6, 2011 | 04:56 PM
turbo-2nr's Avatar
well if every thing fit right before the hone it will be looser after words the hone does make the cylinder slightly bigger, just not as much as a boar would
Old Jun 6, 2011 | 04:59 PM
hello1320's Avatar
run a .00001 PW clearence.... then u don't have to use rings
Old Jun 6, 2011 | 06:22 PM
REEMB18C1's Avatar
LOL
Old Jun 6, 2011 | 06:50 PM
a1320honda's Avatar
Careful...youll get someone that will attempt this very thing.
Old Jun 6, 2011 | 09:54 PM
hello1320's Avatar
I wonder if the slug would even go in ? You'd probley have to hammer it down
Old Jun 7, 2011 | 09:03 AM
lol im sure if you heated the piston first it would make a great tight fit lol. but it was my stupid fault so i blame no one but meyself.. but hey it makes me skip the stock sleeve setup and go right to the sleeved block. mite as well do it now. Someone from GE contacted me with info, great people looking out for the sport.
Old Jun 7, 2011 | 08:03 PM
SPOOLINmatt's Avatar
you should always supply the labeled pistons when boring and honing. If you don't give a clearance, a good machine shop would/should use the "stock" clearance for the pistons.
Ryhaz
10
Jan 14, 2014 07:57 AM
xjdmjunkiex
Apr 17, 2012 11:30 AM
got wide
Sep 4, 2007 03:55 PM
hondaapi
Apr 7, 2005 05:08 AM
speedy108
Dec 26, 2002 07:37 AM
