Pics of Weights
Old Dec 24, 2011 | 11:03 AM
jiggacivic's Avatar
Default Pics of Weights
does anyone have pics of how weights are installed on their drag car and how much weight if you don't mind telling.
Old Dec 25, 2011 | 08:05 AM
MARC P's Avatar
Default Re: Pics of Weights
If your talking about ballast up front, this is how I add weight to my car.
Its about a 140lbs total
Marc P
Old Dec 25, 2011 | 10:43 AM
Garage 808 Hatch's Avatar
I eat cheeseburgers to add weight.
Old Dec 25, 2011 | 11:00 AM
bauergold's Avatar
+1
Old Dec 25, 2011 | 12:07 PM
jiggacivic's Avatar
if i ate a lifetime of cheese burger i still wouldn't have enough weight, i am 120+
Old Dec 26, 2011 | 05:12 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
So many 10yr old boys drive hondas lol.
Old Dec 26, 2011 | 05:34 AM
surfingsk8r's Avatar
Dude seriously if your that light get into roadracing motorcycles you would kill it around the track simply on weight alone as for the balast weight for a car try to focus on not adding weight if you have to but moving weight around so its in the right area.
Old Dec 26, 2011 | 12:11 PM
DraginX's Avatar
I think that is what the OP is looking to learn. How people are adding weight to their cars to balance it out and what methods they are using. Or atleast that is what I assumed he was looking for.
Old Dec 26, 2011 | 02:41 PM
MARC P's Avatar
you can corner balance cars without using weights
Old Dec 26, 2011 | 02:51 PM
LowBudgetBEe's Avatar
will the corner balancing help dramatically because i was thinking of having it done over the winter.
Old Dec 26, 2011 | 05:18 PM
jiggacivic's Avatar
if your profile is correct i bet you will never catch up to my age (always 3 years ahead) lol.
exactly.
Old Dec 26, 2011 | 09:05 PM
CO_RaceFab's Avatar
This
Old Dec 27, 2011 | 05:17 AM
DraginX's Avatar
I've seen people corner balance their cars by raising their suspension to compensate for different areas of the car. This is ideal for an all out drag car, but for someone like me that will still drive the car on the street this isn't ideal so a weight system would be much better unless the car is only out a very little bit.
Old Dec 28, 2011 | 06:36 AM
pb16b's Avatar
corner balancing isn't just for drag cars... as a matter of fact, is more for road race cars.
Old Dec 28, 2011 | 06:46 AM
turbo-2nr's Avatar
yes but when you corner balance a drag car you try and shift as much weight to the front wheels as you can, with a auto x car you try to get even weight as you can an all four corners
Old Dec 28, 2011 | 12:52 PM
MARC P's Avatar
You don't need to raise and lower car to shift weight.
Set your desired height and then mess with spring tension.
Marc P
Old Dec 28, 2011 | 08:07 PM
Divers's Avatar
Marc P
X2
allmotorhonda
Jan 2, 2003 04:55 PM
Apocalypse
Nov 8, 2002 04:45 AM
