Pic request: turboed H22's in EG with traction bar AND catch pan
looking under my car i feel like my brain is going to explode thinking about how i'm going to fit a traction bar and a catch pan under there. ground clearance is already of the essence and so is space under my hood. if anyone has pics of the underside of their car with these on that would be great to see. i guess b18's are welcome too.
Banned
Re: Pic request: turboed H22's in EG with traction bar AND catch pan (Mikey3000)
I just took my traction bar out till I can fab up some new charge pipes. Was literally right in the way. Its such a tough fit.
Re: Pic request: turboed H22's in EG with traction bar AND catch pan (sctuned)
i was looking into it a while ago and was going to try to go from the back fowards (behind motor fowards instead of front motor backwards)
will ty to get a pic up for you when i get mine mounted, it is a h22 in a 98 civc
I re-made my down pipe so its barely off oil pan {i used oval pipe under pan} then put a mandel bent "hump" in pipe to get over rear edge of catch pan.. my pan is kinda diamond shaped to keep inside traction bar but with flatten sides under crank pulley and trans end case hope this helped good luck..
Finland
Welding / Fabrication
06-05-2006 08:17 PM
X-Mazda 3 Racer
45
05-01-2005 08:06 PM
mister2racer
02-25-2004 07:32 AM
