part out
Old Jun 10, 2008 | 05:52 PM
I B BANGGIN's Avatar
Default part out
all parts are fairly new with only a few dyno pulls on...
will send pics if needed..parts are located in houston texas, buyer pays shipping
feel free to contact 281 736 7889 ricky
rcantu83@yahoo.com
lenso rims and slicks , about 10 passes,13x7 and 24.5x8x13...$450
bogart runners with tires 15x3 (i think) $400
ctr tranny with 4.78 final drive, podrive spool, circut worx speed sensor ring gear, will throw in shift linkage...no grinds $1200
competition clutch twin disk with about 5 dyno pulls, no track time..$950
complete fuel system..2 gallon jaz fuel cell with roll over vent, aeromotive a100 fuel pump, aeromotive fpr, fp guage, skunk2 composite fuel rail, all earls fittings and steel braided lines....uses -10an for feed and -8an for return...$650
precision 1000cc injectors...$175
complete b16 longblock...81.5bore 9:1 compression supertech pistons, eagle rods, golden eagle block guard, mirco polished and balanced crank, new water pump and oil pump(westside performance did all work), port and polished head, supertech 1mm oversized valves (flat) supertech valvetrain, ctr cams, skunk2 cam gears, 0bd1 dist, alt, ngk power plus wires, all new honda bearings and gaskets...$2000
edelbrock (b16) intake manifold with hondata gasket $275
alum radiator with slim fan...$150
comp engineering traction bars..$175
bdl 72mm trottle body..$250
endyne catch can with all -10 an fitting and steel braided lines..$125
ati dampner (race version)...$300
golden eagle scatter shield...$150
golden eagle vac block...$45
complete turbo kit..full race ram horn manifold, tial (purple) bov, tial 38mm (silver) wastegate, nando fab 3in side exit down pipe, dump tube 3in piping (cold side) 2 1/2 (hot side), all 4ply couplers, tbolt clamps, feed line, return line, 3in intercooler, 3bar map sensor, turbonetics dual bearing t62-1 turbo, p28 with basemap for start up.....$2700
msd 6al ign..$75
rolling race car shell....92 honda hatchback, all new lexan windows, 8pt cage, parachute mount, cnc staging brake, ken kustoms brake master cylinder, all new custom steel braided lines, kirkey alum racing seat, fuse panel, automete silver guages (water temp, oil press., volts, boost, rpm tach) fiber glass one piece front end, 1k rear progressive springs, kyb 5way adjustable, skunk2 coil over for front, omni front camber kit, d2 camber kit for rear, fresh paint from gbc customs....$3000
Old Jun 10, 2008 | 05:53 PM
Default Re: part out (I B BANGGIN)
damn thought i was in for sale section...please close
Old Jun 10, 2008 | 06:12 PM
Clayton's Avatar
H-T Administrator
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I B BANGGIN &raquo;</TD></TR><TR><TD CLASS="quote">damn thought i was in for sale section...please close</TD></TR></TABLE>
Done
ls_on_boost
Jul 1, 2014 08:03 AM
ls_on_boost
Jun 29, 2014 05:25 AM
Zero2Sixty
Jun 20, 2004 01:05 PM
hpfsi
Nov 7, 2003 07:01 PM
