oiling question...
Old Nov 21, 2011 | 03:49 AM
dropped93ex's Avatar
Default oiling question...
Got a built gsr with a pre journal bearing 6262 ... Can I run my oil feed from my oil pressure sender hole and is a -3an feed sufficient enough for 6262 oiling without a restrictor? Thanks guys for the help
Old Nov 21, 2011 | 04:15 AM
v.i.gsr's Avatar
Default Re: oiling question...
Yes you can run your oil feed from you oil pressure sender hole, just make sure you use the right size fitting..
I run a -3 with my billet 6765, with a .65 restrictor for insurance, but I'm at 90psi on start up and at wide open throttle.. It all depends on what oil pressure your seeing...
Old Nov 21, 2011 | 05:34 AM
Ok thanks brother.. just wanted to make sure -4 wasn't necessary
Old Nov 21, 2011 | 06:04 PM
welfarepc's Avatar
im running -3 non-restricted from the sender port on my journal 6262. no issues.
Old Nov 21, 2011 | 06:35 PM
Just what I wanted to hear!!
deeboii2014
Apr 1, 2015 05:48 AM
NIGHTRIDER27
Apr 9, 2008 06:51 PM
cdog19
Feb 9, 2004 01:15 PM
DamonBoost
Jun 16, 2002 04:24 PM
