Oil Pump Keeps Breaking
Old Aug 23, 2007 | 12:46 PM
NOKTURNALCARCLUB's Avatar
Default Oil Pump Keeps Breaking
Not sure if this was the right Forum but i figured since it's drag related more of you would know about this and have info for me than in the 92-00 forum.
I'm on my 4th Oil Pump Already, keep breaking em. 2 were broken on the dyno and one at BOTI Sacramento. I ordered the ATI Super Harmonic Balancer Damper to try it out and and see what happens.
any ideas on why i keep breaking em? Made 741whp and 500tq.
Old Aug 23, 2007 | 01:09 PM
h22 civic's Avatar
Default Re: Oil Pump Keeps Breaking (NOKTURNALCARCLUB)
its a very touchy subject that oil pump breaking issue lol....IMO put a external system in and dont look back!!!unless you are running a certain class that dont allow it...then id still put the pump in and say to hell with that class ..i learned my lesson after poping 2 motors and 20,000 down the tubes usualy when the pump goes the motor isfubared,head ,cam ,turbo,rockers,crank,rods,pistons ,etc i put a external few years back and have had no issues what so ever and those are my 2 pennies on that subject
Old Aug 23, 2007 | 01:25 PM
qfast817's Avatar
Default Re: Oil Pump Keeps Breaking (h22 civic)
what flywheel/clutch are you running?
Old Aug 23, 2007 | 01:38 PM
Default Re: Oil Pump Keeps Breaking (qfast817)
I want to keep the car in S/C class SFWD.
I am currently running ClutchMasters Twin Disc.
Old Aug 23, 2007 | 02:11 PM
PHDZINE's Avatar
Is the pump shimmed? If the pump is shimmed too much ,it could possibly causing it to break. What is your oil pressure at WOT?. Maybe your crank is bent and the harmonics are causing it to break.
Old Aug 23, 2007 | 02:17 PM
Turbo-charged's Avatar
Default Re: Oil Pump Keeps Breaking (PHDZINE)
was the block line honed? if so, by who?
when originally talking with stewart engines about my engine program, was right around the time the big dogs of spfwd were constantly breaking oil pumps. i obviously wanted to avoid that and jim was confident he had the answer.
sure enough, 860whp and 2 FULL season's later....im still on the same oil pump and the same motor.
http://www.stewartengines.com
Old Aug 23, 2007 | 02:23 PM
DrVtec99's Avatar
I would say harmonics would play a part in the pump, What kind of crank pulley are you running? I have seen people use aftermarket pulleys with no harmonic dampening abilities cause oil pump and also rod bearing failure
Old Aug 23, 2007 | 02:56 PM
turbotypeR@SPEC's Avatar
25 Year Member
What damper where you running? I see pumps break from the harmonics of the twin disc. An ATI damper usually fixes it.
skunkyturbo's Avatar
Default Re: Oil Pump Keeps Breaking (DrVtec99)
Ask him he knows
Old Aug 23, 2007 | 04:10 PM
h22 civic's Avatar
Default Re: Oil Pump Keeps Breaking (skunkyturbo)
def runa damper i like ati
Old Aug 23, 2007 | 05:45 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOKTURNALCARCLUB &raquo;</TD></TR><TR><TD CLASS="quote">I want to keep the car in S/C class SFWD.
I am currently running ClutchMasters Twin Disc.</TD></TR></TABLE>
I ran that same clutch and was breaking oil pump gears. I switch to a Fludampr crank pulley and have not had a problem since.
Old Aug 23, 2007 | 07:04 PM
Garcia-Racing's Avatar
Tell Jerry he has to put a new gear in, he can't weld up the old one.
Old Aug 23, 2007 | 10:07 PM
siphonda's Avatar
hi y had the same problem with a all motor car 1 time broke the oil pump and y put a ati damper and still broke the 2 oil pump y am going to take the crank too the machinge shop check the crank before you asembel the engine
Old Aug 24, 2007 | 10:33 AM
Im gonna try the ATI damper, If the Oil Pump breaks again then we're gonna replace the crank with a new one... Thanks for the info fellas!
Old Aug 24, 2007 | 10:37 AM
Default Re: (NOKTURNALCARCLUB)
call me crazy....but i think i'd replace the crank--check the machine work before i let it break another pump and destroy everything?
g2man
Nov 30, 2004 09:03 PM
Griffin@Camtech
Apr 14, 2004 04:41 PM
