oil pickup issues
Old Sep 17, 2010 | 01:49 PM
Garage 808 Hatch's Avatar
Default oil pickup issues
Anyone ever broke a Moroso oil pickup? Last time at the track, i had ignitor and trans issues. no engine issues what so ever. I fixed those issues, go to load the car in the trailer for BOTI Woodburn, and 0 oil pressure. WTF? checked oil level, fine. checked gauge working, fine. drop the pan, looks fine. start unbolting the pickup, it falls to the ground with the flange still bolted to the oil pump. the weld holding the tube to the flange had broke completely loose. Got it welded back up, but has anyone else had this issue?? oem or aftermarket
Old Sep 17, 2010 | 02:28 PM
Default Re: oil pickup issues
Heres the damage
Old Sep 17, 2010 | 03:17 PM
hello1320's Avatar
I re welded mine inside and outside before I used it......the domestic guys said to do it......good u got it while u did though
Old Sep 17, 2010 | 03:20 PM
i just did that
Old Sep 17, 2010 | 03:45 PM
Urban_Indian's Avatar
good call. Next time I pull my pan Im going to weld that up
Old Sep 17, 2010 | 04:27 PM
hello1320's Avatar
Originally Posted by Garage 808 Hatch
i just did that
It's money then.....run some 8s...
Old Sep 17, 2010 | 05:31 PM
Just need it to dry up. Trying to go tomorrow, if the rain holds out a bit.
Old Sep 17, 2010 | 05:41 PM
tony1's Avatar
Yup, noticed the weld was half *** on mine and had been ground down by moroso. Fixed it before it became a problem.
Old Sep 17, 2010 | 07:44 PM
Well, i'm glad i caught it at home instead of at the track. It had fine oil pressure when I put it in the trailer after the last race. Maybe it was just held in there by thermal expansion or some **** from the passes. IDK. Just weird
Old Sep 17, 2010 | 10:18 PM
JFK78's Avatar
The same thing happened to ours a few months ago. Re-welded and it's been good ever since.
Old Sep 17, 2010 | 11:50 PM
V-SPEC 1's Avatar
Is this pickup from the aluminum pan or the 5 quartz steel pan. Good luck with the race.
Old Sep 18, 2010 | 01:59 AM
cibao2ner's Avatar
good to know thanks for posting..i have an aluminum pan im gonna need this oil pick up..now i can get it welded before i use it...did u tig or mig?
Old Sep 18, 2010 | 02:17 AM
KStuned's Avatar
We tig our oil pickup tube to the flange in our H2b oil pans and haven't had an issue.
Old Sep 18, 2010 | 07:29 AM
Mine was from the aluminum pan setup. Tig'd inside and out now
Old Sep 18, 2010 | 07:51 AM
V-SPEC 1's Avatar
My bad, If I remember correctly the steel ones uses the oem pickup tube "Gsr/ITR"
ballisticej1
13
Jun 14, 2009 08:50 AM
hondaboy4life
Sep 29, 2006 08:01 AM
rival12
Sep 20, 2005 04:29 PM
Muckman
Jul 20, 2004 01:35 PM
Kalokohan
Aug 7, 2001 12:54 PM
