Oil catch can
Old Aug 11, 2004 | 06:03 AM
sleeperHatch's Avatar
Default Oil catch can
Can someone with an oil catch can post pics of where you have yours located. And where did you purchase yours from?
Old Aug 11, 2004 | 06:43 AM
underpressure02's Avatar
Default Re: Oil catch can (sleeperHatch)
Don't have any pics at work. But I have the z10 can. The only place i could fit it in my cluttered engine bay was on the passenger side behind the headlight where the round hole is. This is on a 92 civic hatch.
Old Aug 11, 2004 | 08:54 AM
SpeedDreamz.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperHatch &raquo;</TD></TR><TR><TD CLASS="quote">Can someone with an oil catch can post pics of where you have yours located. And where did you purchase yours from?</TD></TR></TABLE>
NIck, bring it by the store and I wil do it for you. Do you have the block fittings? If not I have some here at the store. I can get you any can you need. I personally use the Z10 unit.
Tracy.
Old Aug 11, 2004 | 09:23 AM
Default Re: Oil catch can (30psiCiv)
30psiCiv can you put the block fittings on the block with the motor in the car? Or do you need to remove the intake manifold. I have the fittings but have not attemped it yet. I was not sure if I could do it with the motor in the car or if I would need to take off the intake manifold.
Old Aug 11, 2004 | 09:59 AM
Default Re: Oil catch can (underpressure02)
If you have any questions....Tracy(30psiciv) is the man to ask!!
Old Aug 11, 2004 | 10:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">30psiCiv can you put the block fittings on the block with the motor in the car? Or do you need to remove the intake manifold. I have the fittings but have not attemped it yet. I was not sure if I could do it with the motor in the car or if I would need to take off the intake manifold. </TD></TR></TABLE>
SHoot yes. You will have to do it from the bottom though.
Old Aug 11, 2004 | 11:30 AM
next question so I don;t have to search. What size do I need to get that hex bolt out? I think it is hex shaped.
Old Aug 11, 2004 | 01:42 PM
actually I went cheap and used a 17mm head bolt and locked two nuts on the other end and backed the fitting out with a wrench.
Shaun
Oct 18, 2007 07:38 AM
top
Mar 19, 2007 01:31 AM
dpkelly
Mar 10, 2007 11:24 AM
chasemyhonda
Nov 1, 2006 08:49 AM
