to o-ring or not to o-ring that is the question?
Old 06-25-2008, 05:26 AM
  #26
tony1's Avatar
Default Re: (wHOAlly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly &raquo;</TD></TR><TR><TD CLASS="quote">the AEM ProRWD car ran only O-rings </TD></TR></TABLE>
Haha
GE sleeves and copper o rings on my motors.
Old 06-25-2008, 01:51 PM
  #27
jdm inc's Avatar
Default Re: to o-ring or not to o-ring that is the question? (Ef Si)
what head gaskets are you guys running with the o-ring blocks? cometic?
Old 06-25-2008, 02:10 PM
  #28
Golden Eagle's Avatar
Default Re: to o-ring or not to o-ring that is the question? (jdm inc)
oem Honda overboard to match your bore size is always the best they tend to hold the most hp with no problems
Old 06-25-2008, 04:40 PM
  #29
1992Si's Avatar
Default Re: to o-ring or not to o-ring that is the question? (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">oem Honda overboard to match your bore size is always the best they tend to hold the most hp with no problems </TD></TR></TABLE>
GE sleeves and o-rings for the new engine.
Old 06-25-2008, 04:52 PM
  #30
SPOOLINmatt's Avatar
Default Re: to o-ring or not to o-ring that is the question? (1992Si)
i run the copper o-rings. I hate replacing them when i have removed the head for something but i've never blown a head gasket using my step decked o-ringed block.
Old 06-25-2008, 05:00 PM
  #31
jdm inc's Avatar
awesome so no special gasket thanks alot.
Old 06-25-2008, 05:03 PM
  #32
ALL IMPORT's Avatar
well ive done some research & it seems simple enough 2 do. so my question is cant u make like 2 sets of o-rings so if u do pull the head u already have a set on standby just in case?
Old 06-25-2008, 05:13 PM
  #33
DaveF's Avatar
Default Re: to o-ring or not to o-ring that is the question? (ALL IMPORT)
the wire comes in a spool. it takes about 30 seconds to do a cyl.
Old 06-25-2008, 10:47 PM
  #34
ninesecrx's Avatar
Default Re: (ALL IMPORT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">well ive already experienced an issue with a stock deck & a cometic head gasket.
must of went in the beginning of the run then up top this happens.
this was only running 30 psi also car ran for over a year not 1 problem then things went wrong. now im going for 40+psi so i dont need theese issues.
notice everything else looks good, lol
Why would a o ring help this problem? That was above the o ring and head gasket.
Old 06-25-2008, 10:49 PM
  #35
NooB
IT'S ME DAVID's Avatar
Default Re: (Innes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innes &raquo;</TD></TR><TR><TD CLASS="quote">we have always run copper o-rings -- for us, if it ain't broke, don't fix it</TD></TR></TABLE>
Old 06-26-2008, 04:13 AM
  #36
ALL IMPORT's Avatar
Default Re: (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">
Why would a o ring help this problem? That was above the o ring and head gasket. </TD></TR></TABLE>
because it started with just the gasket blown then the exhaust started escaping & burnt the the hole in the head my darton sleeves were barely even effected thuse being hard as hell & the head soft. so the o-ring in my opinion would of backed the h-gasket up & would of held. any opinions?
2 darton
ill post a pic of the sleeve when i get home.
Old 06-26-2008, 04:47 AM
  #37
miller's Avatar
that was deff not caused by a headgasket.
Old 06-26-2008, 05:34 AM
  #38
tony1's Avatar
Default Re: (miller)
That was caused by a blown headgasket...
Old 06-26-2008, 05:49 AM
  #39
DaveF's Avatar
Default Re: (tony1)
what caused the headgasket
Old 06-26-2008, 06:04 AM
  #40
X-Mazda 3 Racer's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">That was caused by a blown headgasket...</TD></TR></TABLE>
Blown headgasket caused by:
a= inadequate clamp load from block to head through the gasket
b= being too aggressive with the timing ( a headgaskets WORST enemy )
c= a lean condition causing pre-ignition and a hotspot on the gasket / head
d= surface irregularities or voids that allow gas to accumulate and burn ( another form of pre-ignition )
There are so many factors to think about. What do you guys see from the picture? Any clues?
Old 06-26-2008, 06:47 AM
  #41
SpeedDreamz.com's Avatar
Default Re: (X-Mazda 3 Racer)
copper o-rings here 2
Old 06-26-2008, 04:44 PM
  #42
ALL IMPORT's Avatar
Default Re: (SpeedDreamz.com)
i thought i said it was the head gasket that went, THEN by running down the track all the blow-bye took a tool on the head. the sleeve didnt get that hurt cause it was steel.
as u all know when hot stuff escapes it burns
so now
a- would the o ring of helped back up the head gasket?
b- put more clamping load on the gasket causing the blow bye 2 not occure?
c- car was deff conservative with timing afr was like 11.7
oh aslo head was torqued at 90ftlbs. what do u guys norm do?
aslo the car was running for a year at 650whp on & off the track got about 4000miles out of it including 750 break in miles. no issues. so maybe i needed to re torque the head ? guess i was lazy
heres a pic of the sleeve. & the head gasket just for study. opinions welcome would oring's of hepled.
Old 06-26-2008, 06:20 PM
  #43
swapit's Avatar
i had my block done with orings but never used the oring and never had a problem with a oem headgasket.cometics dont like boost seem to never work on high boost apps.
GOLDEN EAGLE for me()doing the same on the new rebuild but using the orings this time)
Old 06-26-2008, 11:32 PM
  #44
pro-motion's Avatar
Default Re: (swapit)
I would think if the car ran fine for a year and then all of a sudden had this issue, something changed? Maybe you have a ign. problem? Have you looked into a dropped sleeve? That is something that also could change and create a problem this this real quick.
If a copper o-ring helps seal the bore, why not just use copper spray on the entire head gasket before use? I could see using a steel o-ring with a copper head gasket making a difference, but not a soft wire. Steel on steel obviously seals very well by itself, why cut a groove into the deck and add something that is not steel? Also when you cut a groove into the deck, would that not limit the bore size one can go with the block?
Old 06-27-2008, 05:21 AM
  #45
ALL IMPORT's Avatar
Default Re: (pro-motion)
i was wondering the same. especially with the darton sleeves i got cause wouldn't u have 2 o-ring the sleeve itself, ?
Old 06-27-2008, 07:24 AM
  #46
yes the oring sits on the top of the sleeve
Old 06-27-2008, 07:29 AM
  #47
1992Si's Avatar
Default Re: (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">yes the oring sits on the top of the sleeve </TD></TR></TABLE>
In a grove machined for it.
Old 06-27-2008, 07:35 AM
  #48
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro-motion &raquo;</TD></TR><TR><TD CLASS="quote">I would think if the car ran fine for a year and then all of a sudden had this issue, something changed? Maybe you have a ign. problem? Have you looked into a dropped sleeve? That is something that also could change and create a problem this this real quick.
If a copper o-ring helps seal the bore, why not just use copper spray on the entire head gasket before use? I could see using a steel o-ring with a copper head gasket making a difference, but not a soft wire. Steel on steel obviously seals very well by itself, why cut a groove into the deck and add something that is not steel? Also when you cut a groove into the deck, would that not limit the bore size one can go with the block?</TD></TR></TABLE>with the copper oring when you bolt the head down it smashes and gives more sealing power it is a method proven to work by the many racers that have run them over the years.
we can do a max of 85mm bore with a oring and that is max turbo bore so for a boosted app this limits you in no way.
copper spray can help but no ware near as much as a oring they are 2 different things should not even be compared to each other.
Old 06-27-2008, 09:34 AM
  #49
pro-motion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">with the copper oring when you bolt the head down it smashes and gives more sealing power it is a method proven to work by the many racers that have run them over the years.
copper spray can help but no ware near as much as a oring they are 2 different things should not even be compared to each other.</TD></TR></TABLE>
So the copper seals better to the steel gasket? Why not just have the entire top of a sleeve be copper then? Why limit your self to just a tiny wire? Does this soft copper wire the smashes flat do anything for sealing above the head gasket between the head and gasket?
Old 06-27-2008, 09:42 AM
  #50
ALL IMPORT's Avatar
what does it cost on a gsr block?
Quick Reply: to o-ring or not to o-ring that is the question?
