none vtec head v vtec head
(not a road car)
i've seen people lock there vtec but would it not be better to just use a none vtec head with some big cams. i guess you will have less rotating mass in the topend ?
VTEC heads flow way better and the valve train is more high RPM stable etc... I used to have a ported LS head with a nice valve train package and thought I was doing all the good...Until I got a VTEC head. Night and day difference.
only reason i asked was ,i read on here that mark p used a none vtec head on there race car ,i msg him about it but they never replyed.
i dont know if its top secret mod or somthing like that , so thought id ask .
If you try to use a non vtec head to safe money, it will be WAY more money to modify it and it will still flow the same or less? than a stock port vtec.
I've been looking for flow charts and can't find anything.
Found it. After porting and vj it flowed more than a stock pr3 with no manifold. And that's a P8r head with with the 33mm intake valves.
https://honda-tech.com/all-motor-nat...esult-2709206/
OP,
The comments were assuming you were discussing B series cylinder heads.
Marc P runs K series stuff and K series OE non vtec heads are a totally different ball game.
k series you can use the k24a1 non vtec head and it will port exactly the same as a k20a2 head.
people thought you were talking about b series heads.
i have a k24a1 head on my 2.7 k.
the only advantage to this is the head is cheaper. afterkmarket rockers or oem vtec killer rockers can be used on either head.
i was talking about b series, the thread i read when he said he used a none vtec head was about a b20 none vtec race car.so i just thought he was talking about a b series.
civictildeath
Aug 2, 2006 08:22 PM
full Circling
Aug 22, 2005 09:05 PM
