No filter
Old Jan 14, 2004 | 06:02 PM
TylerB's Avatar
Default No filter
So, whats the deal with running w/no airfilters, is this bad on the motor? i can see if a big leave gets in its not going to run good, but other than that is there any major disadvantages? any advantages?
Thanks
Old Jan 14, 2004 | 06:09 PM
Jared's Avatar
Default Re: No filter (94prelude)
disadvantage all around unless you're running it on a race car. any kind of foreign objects are bad on your rings and valve seats.
Old Jan 14, 2004 | 06:16 PM
TylerB's Avatar
Default Re: No filter (Jared)
well, it is on my "drag" car...so would it be ok or should i just go ahead and put one on?
Old Jan 14, 2004 | 06:47 PM
Used2beAb16's Avatar
just drop the filter when your at the track, i would still put something there though to keep out large objects ie. a leaf, or piece of paper or plastic or any random thing. Ive seen people use hosiery (sp?) just to keep out the big things.
Old Jan 14, 2004 | 07:00 PM
michael O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94prelude &raquo;</TD></TR><TR><TD CLASS="quote">well, it is on my "drag" car...so would it be ok or should i just go ahead and put one on?</TD></TR></TABLE>
I think by drag car he means a car that gets an engine rebuild every few runs.
Old Jan 15, 2004 | 03:13 AM
TurboTony's Avatar
I dont have a filter on my turbo set up, what can i use for a filter some say a screen or somthing of that sort but what kind of screen will not melt or get stuck into the turbo?
Old Jan 15, 2004 | 07:54 AM
Rtype16's Avatar
Default Re: No filter (TurboTony)
On any car even a race car I would use a filter unless the path to the engine has a radiused lip on it of some sort. This will help increase flow through the inlet of the intake pipe. The thing is you have to have a filter that has enough surface area to upply enough flow for the engine to breath without choking it down. On a turbo charged car since the inlet of the turbo is pretty good from the start on most turbos I would suggest just go to Walmart or where ever and buy a metal strainer cut it off the handle and hose clamp it to the front of the turbo.
phaiwezzie
Mar 28, 2008 04:21 PM
austrian type-R
Apr 25, 2003 06:31 PM
1CleanSi
Mar 26, 2003 03:46 PM
2000GSRT
Nov 15, 2002 02:06 AM
