Well i brought the hatch to the track this past sunday.
setup:
92 civic HB
Usdm H22
TypeS cams
TypeS pistons
20 dollar intake
New DC header with 2.5 collector
Apexi WSII catback
chipped P28
street tires (not drag radials)
60ft: 2.1
1/8th:8.9@80mph
1/4: 13.8@102
ran 13.8 3 times
setup:
92 civic HB
Usdm H22
TypeS cams
TypeS pistons
20 dollar intake
Apexi WSII catback
chipped P28
60ft: 2.1
1/8th:8.9@80mph
1/4: 13.8@102
ran 13.8 3 times
will be back to the track in 2 weeks with some slicks..hoping for some 1.7-1.8 60fts if so i`ll hope to get into the mid to lower 13`s
any input. good or bad would be appreicated
Not bad. What does the car weight? With a trap speed of 102, you should be right around 13.1 with a good 60.
High 1.6 low 1.7 if I recall correctly. Unfortunately my slips were left in the car and got soaked one day when it rained so I don't have them anymore to check, but I'm pretty sure they were in that range. Track opens up again in 3 weeks around here, and I'll have some new times to post with the spool installed and on nitrous. Also I was weighing in at 2077 w/driver when I made these passes so your a little heavier, which will slow you down a little.
dang.. back in the day when i had my Si hatch w/ h22 i ran 13.4@100+ with stock everything aside from a clutch and 9lb flywheel.. and my car was a pig w/ full interior and my 230lb big ***
