new boost controller...your thoughts!
Old Nov 19, 2007 | 07:22 PM
  #76
paulzy's Avatar
so let me get this straight.
If I want to use base pressure for launches and 1st gear, I can set up an output in my EMS to trigger the AMS-500 to turn on(hence turning on the first stage) and then it'll ramp up to selected second stage with another output making that 3 stages?
Old Nov 19, 2007 | 09:40 PM
  #77
V-SPEC 1's Avatar
Default Re: (paulzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy &raquo;</TD></TR><TR><TD CLASS="quote">so let me get this straight.
If I want to use base pressure for launches and 1st gear, I can set up an output in my EMS to trigger the AMS-500 to turn on(hence turning on the first stage) and then it'll ramp up to selected second stage with another output making that 3 stages?</TD></TR></TABLE>I believe you are correct.
Old Nov 20, 2007 | 04:06 AM
  #78
NLR's Avatar
NLR
Default Re: (V-SPEC 1)
output from your ems turn on one input( goes to target pressure) when your ems sends another output to the second input on the ems it then goes to the target in that stage.
Old Nov 20, 2007 | 07:48 AM
  #79
scoop's Avatar
Default Re: (NLR)
Old Nov 20, 2007 | 09:22 AM
  #80
tepid1's Avatar
Default Re: (NLR)
Looks very promising Sebastian.
Good stuff man.
Old Nov 20, 2007 | 10:57 PM
  #81
V-SPEC 1's Avatar
Default Re: (NLR)
Can I ask you a question? what is the difference between this and say the Hondata s300 boost controller? thanks.
Old Nov 25, 2007 | 06:42 AM
  #82
NLR's Avatar
NLR
ams-500 instruction manual
http://psychobike.com/cgi-bin/...23157
Old Nov 25, 2007 | 07:42 PM
  #83
V-SPEC 1's Avatar
Default Re: (NLR)
looks good. Can't wait.
Old Nov 26, 2007 | 07:17 AM
  #84
ExVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">Can I ask you a question? what is the difference between this and say the Hondata s300 boost controller? thanks.</TD></TR></TABLE>
Good question, interested as well.
If possible I think $299 would be a helluva deal on that.
Literally blow everything else out of the water.
Old Nov 26, 2007 | 07:44 AM
  #85
MeanGreenMachine's Avatar
Default Re: new boost controller...your thoughts! (BEEYOND)
NLR have an E.C.D (Estimated completion Date) on this ams-500 yet?
Old Nov 26, 2007 | 09:04 AM
  #86
NLR's Avatar
NLR
Default Re: new boost controller...your thoughts! (MeanGreenMachine)
Tempest will have the first unit to test before the end of this week.
Old Nov 26, 2007 | 09:19 AM
  #87
2fast4u831's Avatar
I'm really 2slow
Default Re: new boost controller...your thoughts! (NLR)
this will make a great christmas gift for myself
Old Nov 27, 2007 | 02:32 PM
  #88
I.C.C.'s Avatar
Subscribed, and added to Christmas list... haha
This is perfect. Exactly what Ive been looking for!!! I can finally get rid of my ancient profec b spec 1!!! lol
Old Nov 27, 2007 | 06:59 PM
  #89
red cx's Avatar
Default Re: (I.C.C.)
wow man looks very good
Old Dec 8, 2007 | 06:31 PM
  #90
Tchleung's Avatar
Okay I'm not too concerned about the ramp feature. what I'm wondering is, I want to run wastegate pressure for the first 2 gears, then stage 1 for 3rd gear, then stage 2 for 4th and 5th gears. Is that possible with this unit? If It's powered up with a + and -, but no input signal sent to either inputs, will this leave me at wastegate pressure?
Old Dec 8, 2007 | 07:39 PM
  #91
Turbo-charged's Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Okay I'm not too concerned about the ramp feature. what I'm wondering is, I want to run wastegate pressure for the first 2 gears, then stage 1 for 3rd gear, then stage 2 for 4th and 5th gears. Is that possible with this unit? If It's powered up with a + and -, but no input signal sent to either inputs, will this leave me at wastegate pressure?</TD></TR></TABLE>
yes its possible to do that. you run no + or - to either input for first and second gear. you would send a + or - to input 1 in 3rd gear and another + or - to input 2 for 4th and fifth gear. if you dont want a ramp, you dont have to have one...but the option is there. keep in mind with the ramp feature, you can start ramping in the boost in 3rd gear so that by the time you get to 4th or 5th gear your there already, but brought the boost in sooner so your going faster...
Old Dec 8, 2007 | 07:41 PM
  #92
Default Re: (Turbo-charged)
should have some test results up this week
Old Dec 8, 2007 | 07:53 PM
  #93
the s300 boost controll works pretty well. obviously for the guys running s100-s200 this controller is a no brainer. this will also blow away any greddy controller or anything like that.
with the s300 you are locked into a certain boost per gear with no ramp rates. one big thing that i REALLY like about th NLR controllers is that they regulate how much pressure is applied to the top of the wastegate....no more throwing duty cycle at it hoping its going to make more boost untill you get to the point where it starts working. you dont have the issue where 1 or 2 percent duty cycle is making a wide range of boost thats hard to controll. another big thing is that this controller uses a decrease solenoid so you can run a higher boost level and bring the boost DOWN when you trigger one of the inputs. you can also use c02 and it will vent through the decrease solenoid if there is a problem or when you need to reactivate one of the lower stages.
there is also an endless amount of possibilities on how you can set up triggering the different stages. if your creative, you can get it to do whatever you want
i will have an AMS-1000 in my racecar, and an AMS-500 in my street car
  #94
2fast4u831's Avatar
I'm really 2slow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">
yes its possible to do that. you run no + or - to either input for first and second gear. you would send a + or - to input 1 in 3rd gear and another + or - to input 2 for 4th and fifth gear. if you dont want a ramp, you dont have to have one...but the option is there. keep in mind with the ramp feature, you can start ramping in the boost in 3rd gear so that by the time you get to 4th or 5th gear your there already, but brought the boost in sooner so your going faster...</TD></TR></TABLE>this is what im still wondering about. so lets say like 10 psi 1st gear(spring pressure), 15 psi 2nd gear(1st stage) and lets say I wanna do 35max psi 3-4th gears. Can I increase the boost per second with the ramp feature? lets say something like 5psi per second with the ramp feature..... is that possible?
Old Dec 8, 2007 | 07:55 PM
  #95
Default Re: (2fast4u831)
your exactly right
Old Dec 8, 2007 | 08:13 PM
  #96
Tchleung's Avatar
Great! thanks for the info!!
Old Dec 21, 2007 | 01:27 PM
  #97
bern's Avatar
really looking forward to this unit!
Old Dec 21, 2007 | 03:11 PM
  #98
.RTErnie's Avatar
Default Re: (bern)
This sounds amazing! Let me know when I can buy it!!!!
Do I really need TWO boost control solenoids?
Old Dec 21, 2007 | 03:24 PM
  #99
2fast4u831's Avatar
I'm really 2slow
Default Re: (.RTErnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">This sounds amazing! Let me know when I can buy it!!!!
Do I really need TWO boost control solenoids? </TD></TR></TABLE>if I remember correcty, 1 is to increase pressure and the other decreases pressure
Old Dec 21, 2007 | 03:32 PM
  #100
cluelessmale's Avatar
yep
