Need some wiring help.
Old May 18, 2008 | 08:10 PM
RedneckRicer's Avatar
Default Need some wiring help.
ok im working on my EG hatch. I got a Painless Universal 20 circuit kit off a friend. i got it pretty much got the main stuff wired in.
Just left is to make a wiring harness for the ECU
Now this Kit has a tiny *** 12 Gauge wire for a starter. and also has a Coil out wire on the harness.
Im going to be using a P28 S300 for the car. Fuel injectors will be powered by FJO Injector Driver. using M&W Pro 10 with Crane Coil. i already have a 15 amp 14 gauge wire ran for the ECU Power.
Now does the stock ECU send power to the following?
Fuel Pump
Ignition Coil
Radiator Fan
Does the Starter Hot wire come From the Ignition Switch?
what 2 wires from the ECU do i use for the CEL jumper to set timing and check codes?
Im using 16g GXL wire for all the ECU wires. are there any wires coming out of the ECU that need thicker gauge wiring?
is the Distributor the only sensor that has shielding on it? should i shield any other sensors?
Thats all my questions.. Hope someone can help me out who's done this more. Thanks
Old May 19, 2008 | 12:00 AM
hope someone can help me i got alot of wiring to get done really wanna get started on it tommorrow.
Old May 19, 2008 | 02:33 AM
DaveF's Avatar
Default Re: Need some wiring help. (RedneckRicer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedneckRicer &raquo;</TD></TR><TR><TD CLASS="quote">
Fuel Pump main relay
Ignition Coil underdash fuse box
Radiator Fan underhood fuse box
Does the Starter Hot wire come From the Ignition Switch?main starter wire to battery, small wire goes to ign switch and oem ecu
what 2 wires from the ECU do i use for the CEL jumper to set timing and check codes? you only need one wire, ground it, and cel will flash
is the Distributor the only sensor that has shielding on it? should i shield any other sensors? in an oem harness the 3 sensors in the dist are shield wire, as well as the vss
Old May 19, 2008 | 09:26 AM
Thanks.
Old May 19, 2008 | 08:00 PM
more input..lol
Old May 20, 2008 | 12:22 PM
Kataku2K3's Avatar
Default Re: (RedneckRicer)
Not that it really matters, but the VSS is not normally shielded. Dave's right about the dizzy wiring though. From the factory the knock sensor and O2 signal lines are both shielded as well.
On an OBDI setup, ground the SCS line (D4), and you'll activate the CEL output (A13). A13 is ground trigger for the CEL, so a positive must be run to the other side of the light.
Modified by Kataku2K3 at 1:52 PM 5/20/2008
Old May 20, 2008 | 09:11 PM
alright but on my list to. thanks.
Old May 21, 2008 | 12:11 PM
anyone else got any info for me?
90, 91 miata
Aug 12, 2011 01:06 PM
Corksil
Jul 14, 2011 09:08 PM
90civSi
Dec 5, 2005 06:29 PM
BlueShadow
Jun 20, 2005 03:24 PM
a1-bb1
Sep 23, 2002 01:12 AM
