need some experienced help on mph
Old Mar 5, 2012 | 06:23 PM
sanman000719's Avatar
Default need some experienced help on mph
so i just got tuned this weekend, and well made more power than expected. i need some help from the experienced guys on here as to what mph you think this will come out to.
car is 2240 lbs, and a stock gsr tranny
any help would be apreaciated
Old Mar 5, 2012 | 06:28 PM
Default Re: need some experienced help on mph
oh yah 24.5 x 13 x 9
Old Mar 5, 2012 | 06:36 PM
92redhatch's Avatar
150-155 is usually what the 700whp guys are going. What's the torque numbers.?
Old Mar 5, 2012 | 06:37 PM
459
Old Mar 5, 2012 | 06:38 PM
its just a b16 lol
Old Mar 5, 2012 | 06:52 PM
Green_Goblin's Avatar
With that weight and power...158+
Old Mar 5, 2012 | 07:21 PM
Blown90hatcH's Avatar
How much do you weigh?
Old Mar 5, 2012 | 09:32 PM
turbo-2nr's Avatar
Converting the numbers to SAE( STD whp X .974) brings the power down to 736.31whp i see 145mph-150mph depending on 60ft and driver, if it goes much faster the car will run out of gear in 4th depending what you rev it to, car looks to be a little lean on one of the runs(12.0-12.2) and the map could use a little more smoothing out
Old Mar 5, 2012 | 09:33 PM
bads2k's Avatar
Yeah is that weight with you in the car?
Old Mar 6, 2012 | 02:28 AM
yes with me in the car
and this car was trapping 145 with 580whp in the past
Old Mar 6, 2012 | 03:13 AM
harhoosh's Avatar
At 728, I was traping 157.
Old Mar 6, 2012 | 03:16 AM
wolve's Avatar
still stock short block? max rpm?
Old Mar 6, 2012 | 04:54 AM
oh nonono im reving to 10k
its a rs sleeved b16a2 84.5mm on a 6265
Old Mar 6, 2012 | 05:04 AM
wolve's Avatar
572/383@28 PSI ON E85, AND A PFAB LOG/stock short block.
b16a2/pt67/84.5mm/id2000/677-408@28psi
same as above changed to a 6265/755-425@34
that one threw me off
Old Mar 6, 2012 | 05:15 AM
ahh i meant right above it lol but i can see how that would
Old Mar 6, 2012 | 05:18 AM
the only reason i asked is because whe threw up an overlay of another car he had tunes that trapped 164, and i was like dammm. my setup spooled faster and was a little wuicker through the entire band. I spent my cage money on this new turbo die to alot of shaft play in the other. I just wanted to know what to expect when i do run it full out wich wont be untill a 10 point goes in with my chute.
luck4rmkc's Avatar
Fuel system maxed out?
That some serious power on that little B16 sanman! You still trying to run FIS in Wichita?
Old Mar 6, 2012 | 05:31 AM
umm fuel is fine
aero pro series pump
id2000's
34psi=72.2% duty
Old Mar 6, 2012 | 05:32 AM
fis wont happen man my bumper wont fit the precision 750 cooler
Old Mar 6, 2012 | 05:33 AM
base is at 60psi because im still on stock return lines, but i got -6 on the way
Old Mar 6, 2012 | 05:35 AM
sgnlab's Avatar
She's a little lean down low but great power and I see 150+ mph
Old Mar 6, 2012 | 08:49 AM
061000rr's Avatar
damn near same setup, b16,gsr tranny,10k rev,made 750 at 32psi let off little before 1000ft cause motor let go and log said i hit 152 and coasted thru 1/4 at 148. car is heavy 2. mild steel cage in a eg with little to no weight taken out except rear seats.
Old Mar 6, 2012 | 08:54 AM
close to the same build my head is still stock lol
i figure 155mph
Old Mar 6, 2012 | 08:57 AM
061000rr's Avatar
stock ports here to. i really think car would have done close to 158, i dont think my speedo is very acurate and i coasted 3-400ft and still went 148!
Old Mar 6, 2012 | 08:59 AM
nice so you ran 10???
