Need input please!
Ok i have a 93 cx hatch with a built LS. Benson sleeved to 2.0,o-ringed, crower rods, je 9 to1 compression pistons., Bottem end has been balanced. cranked has been knifed and micro polished. type r flywheel with 6 puck clutch. JG head thats been PanP, 3 angle valve job, SS valves, crower 402 cams. ITR manifold fitted to LS head. basicly im wondering with this set up spraying about a 250 shot would it be capable to make it into the high 10s? thanks for any input!
Getting all that power to the ground is the key
Depending on the weight of the vehicle and if you can get traction, 10's are possible. Just make sure you adjust your timing and have the proper fuel mixture with that much N2O or else you might only be able to make one pass.
