need help with rad support
Old Jan 29, 2011 | 06:41 AM
061000rr's Avatar
Default need help with rad support
im in the process of my first true street build and i cut out the rad support lower half to open it up. i tried to go off some pics that i seen on here but after i cut it the top of the support just collapsed. i put in the 2 pieces of metal for the time but was just wandering what you guys were doing to support the top part. thanks
Old Jan 29, 2011 | 07:01 AM
Turbo-charged's Avatar
Default Re: need help with rad support
If it just collapsed the car must be a bit twisted or something. I usually use the intercooler as the support. Mounts the intercooler and braces the core support. 2 for 1!
Old Jan 29, 2011 | 07:11 AM
061000rr's Avatar
well it collapsed cause i sorta leaned on it! but i def never thought to use the intercooler as the support. thanks man. that actually sounds like a really good idea.
Old Jan 29, 2011 | 07:15 AM
B18c1turboedEK's Avatar
I used my radiator too support it.
Old Jan 29, 2011 | 07:26 AM
rudebwoy's Avatar
I was thinking of cutting out my lower support out also, my main concern was where to mount the bumper and support the bottom of the intercooler, thinking I could weld 1X1 square tube across it, somewhat like the traction bar but on the front side with tabs for the intercooler and bumper. if I finnidh this before you find a solution I will post pics.
Cummins4LF
Jun 9, 2016 05:47 AM
xesvuli420
Aug 6, 2013 12:15 PM
powerdbygarrett
Jul 20, 2007 06:21 AM
int3gra
Apr 12, 2002 08:47 AM
td04civic
Dec 13, 2001 11:36 AM
