need help launching
Old Mar 23, 2006 | 06:30 PM
RATED EG's Avatar
Default need help launching
i have a 94 civic dx hb with a b18b1 block je 11.5 pistons, eagle rods, nuformz block guard, walbro 255 fuel pump, I,H,E , and a stock gsr head....but i just need to work on my launching...im getting 2.3 over and over....i have some shitty *** tires, but i wanna improve my 60ft with those tires so i can understand launches better, i know 2.3 is crappy but i just wanna know some tips
Old Mar 23, 2006 | 07:52 PM
BolivianFuego's Avatar
Default Re: need help launching (RATED EG)
Well first try lowering the pressure to 17psi. That works for me, and Launch at like 4k. If you dont get good amount of wheel spin raise up the launch to 5k but play around there and play with the clutch and gas in first gear, once you hook up good mash the gas and slam into 2nd. This is the most important place where your suppose to gain traction so u get the best time.
Old Mar 24, 2006 | 05:35 AM
1FSTHATCH's Avatar
Well the tires could be the super reason, but if you dont wanna change them then try dropping the pressure in them...17psi sounds about right...Instead of dumping the clutch try slipping it more until you can feel the car actually hook..A problem i know some of my friends were having at the track is there not watching the actual 60ft. mark and shifting right before or on the mark and that will kill your time...make sure you are passing these traps before shifting..Also, try launching around 5k, you dont wanna bog the car and at the same time you dont wanna put yourself into a dead spin or axel hop..
Old Mar 24, 2006 | 10:07 PM
hondah2b21's Avatar
Default Re: (1FSTHATCH)
just a suggestion someone correct me if im wrong. if your car makes enough power you could also try launching in 2nd gear and maybe 5.5k rpms. i was told that due to me having the h2b setup and when i run the car thats what i do but i still have a problem spining thats due to my tires and need traction bar.
Old Mar 25, 2006 | 12:14 AM
RATED EG's Avatar
Default Re: (hondagsr21)
thanks for all the tips any more??
PePpeRedDc5
Apr 20, 2005 06:36 AM
Lost Type R
Aug 17, 2002 01:57 AM
Unsung
Jun 7, 2002 11:41 PM
badnan
May 5, 2002 11:45 PM
DamonBoost
Nov 13, 2001 11:29 AM
