Need help Alcohol abuser!!
Old Sep 18, 2004 | 03:25 AM
Xtreme hatch's Avatar
Default Need help Alcohol abuser!!
I am really interested in using alcohol fuel in my Drag Hatch. Will be a turbocharged 1.8L DOHC engine. Anyone using it already in their cars let me know need some help to get me started.!!!!!!
Old Sep 18, 2004 | 06:21 AM
GRTechnologies's Avatar
Default Re: Need help Alcohol abuser!! (Xtreme hatch)
our civic runs on meth, just make sure you have a good fuel system, something double of what you would need for gas
Old Sep 18, 2004 | 07:31 AM
Gravy's Avatar
if you are going to run meth then make sure you use some good pumps like weldon along with a meth compatible regulator. and some big injectors to match.
Old Sep 18, 2004 | 08:11 AM
earl's Avatar
Default Re: Need help Alcohol abuser!! (Gravy)
You need 2 1600cc injectors per cylinder and big fuel pump at a minimum. An ignition that can fire a 5-1 mixture is also needed.
Old Sep 18, 2004 | 12:05 PM
greenhotrod's Avatar
we are running 8x1600cc injectors with a aeromotive belt driven fuel pump.the more fuel pressure the better.
Old Sep 19, 2004 | 06:11 AM
boosted3g's Avatar
Default Re: Need help Alcohol abuser!! (greenhotrod)
go big with everything, you cant have too much fuel. Youll eat so much fuel youll be wondering how it ever went through the engine. 8 x 1600 is the minimum.
Old Sep 19, 2004 | 12:08 PM
Pacman
Guest
Posts: n/a
Default Re: Need help Alcohol abuser!! (boosted3g)
I have 4/1200 cc on my all motor..... k?A
Old Sep 19, 2004 | 12:15 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted3g &raquo;</TD></TR><TR><TD CLASS="quote">go big with everything, you cant have too much fuel. Youll eat so much fuel youll be wondering how it ever went through the engine. 8 x 1600 is the minimum.</TD></TR></TABLE>Did you get that mis fire figured out yesterday, Josh?
Old Sep 19, 2004 | 12:36 PM
turbo96wr's Avatar
use the waterman fuel pump to the cam sprocket or if your going dry-sump run a mechanical of the pump, it will be the best set-up for your meth....
Old Sep 19, 2004 | 09:02 PM
Modify's Avatar
very interesting
more...............
Old Sep 20, 2004 | 02:15 AM
Yes more more please your opinions and facts are very helpful...
Old Sep 20, 2004 | 06:49 AM
Default Re: Need help Alcohol abuser!! (earl)
we used 8 1600cc inj. and 2 Weldon 2035a's, now were switching to a manual pump with a vacume pump all in 1
Old Sep 20, 2004 | 07:55 AM
Pacman
Guest
Posts: n/a
Default Re: Need help Alcohol abuser!! (turbo96wr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo96wr &raquo;</TD></TR><TR><TD CLASS="quote">use the waterman fuel pump to the cam sprocket or if your going dry-sump run a mechanical of the pump, it will be the best set-up for your meth....</TD></TR></TABLE>
Old Sep 20, 2004 | 07:59 AM
PM-Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Did you get that mis fire figured out yesterday, Josh?</TD></TR></TABLE>
I think he did. i went down there yesterday after they were messing with it and it sounded mean as hell. thats gonna be a monster of a car.
Old Sep 22, 2004 | 02:48 AM
How about maintanece on the whole fuel system and motor?
Old Sep 22, 2004 | 05:16 AM
yellowturbo's Avatar
damn thats a lot of fuel o:
Old Sep 22, 2004 | 05:23 AM
turbo96wr's Avatar
just drain fuel (meth) then cycle regular fuel and leave it in until next event then same process, and have your inj... checked every other race.i never had any fuel problems with this process.
Old Sep 25, 2004 | 07:56 PM
Thank you for that tip will keep that in mind....but still wondering what comp. do meth people run and then tuning process is it the same with any other EMS even the best brand of EMS to run.
Old Sep 25, 2004 | 11:44 PM
ModenaTwinTurbo's Avatar
why do you guys decide to run methanol instead of ethanol? with the ethanol you dont have to go through the fuel drain process and i believe (i may very well be wrong here) that u can make the same amount of power with methanol.
Ed-
Old Sep 26, 2004 | 05:43 AM
boosted3g's Avatar
Default Re: Need help Alcohol abuser!! (ModenaTwinTurbo)
Yeah Earl we got it running, we were planning on going to a few local test and tunes this weekend but there are a couple of things to be worked out first. The problem was the ignition dwell was too short.
Old Sep 26, 2004 | 09:24 AM
STHPERFORMANCE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted3g &raquo;</TD></TR><TR><TD CLASS="quote">Yeah Earl we got it running, we were planning on going to a few local test and tunes this weekend but there are a couple of things to be worked out first. The problem was the ignition dwell was too short.</TD></TR></TABLE>
So its finally done, Thats awsome josh. Let me know if u guys take it to any upcoming test and tune nights. I'd love to come out and see the car in person, Its been along time, Heh, Last time was when the front end was about 5 feet off the garage floor with no motor and a full metal oem front end...
Modified by Tha Shocka at 1:41 PM 9/26/2004
Old Sep 26, 2004 | 09:59 AM
bitemail
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ModenaTwinTurbo &raquo;</TD></TR><TR><TD CLASS="quote">why do you guys decide to run methanol instead of ethanol? with the ethanol you dont have to go through the fuel drain process and i believe (i may very well be wrong here) that u can make the same amount of power with methanol.
Ed-</TD></TR></TABLE>
any info on this?
Old Sep 26, 2004 | 01:14 PM
N2O's Avatar
N2O
We run Ethanol and it is easy to work with! We do not have to drain the fuel system after each race but for the work involved run Meth it makes more power and runs cooler.
Try this:
http://www.battleoftheimports....shtml
Or This
https://honda-tech.com/zerothread?id=860963
Old Sep 26, 2004 | 02:09 PM
Default Re: Need help Alcohol abuser!! (N2O)
good read.
Ed-
Old Sep 26, 2004 | 04:32 PM
h22 civic's Avatar
hondacrx2
Apr 23, 2007 06:13 PM
som3on3_10
Apr 4, 2007 07:25 AM
datnigabluberry
Mar 29, 2007 05:53 AM
big juan
Oct 29, 2005 06:59 AM
Tripz
May 6, 2002 06:04 PM
