need help and advise on engine..
Old Sep 4, 2005 | 09:59 AM
Dragproject-EG9's Avatar
Default need help and advise on engine..
guys i reall need help on this. im on a budget and im hoping to get the most out of my current engine.. specs.
B20B with euro r cl1 85mm pistons stroke is stock.
lighten and balanced crank
strengthen block
ported b16a head
jun stage 3 cams with jun valves, v.springs and retainers.
using dc 2 bored throttle body and intake manifold. [tb bored to 72mm]
running on rechip 10k rev limit ecu with apexi vafc
is there anything i can do to make this engine squeeze out more over mid and top range powerband?
help appeciated.. thanks!
Old Sep 4, 2005 | 10:02 AM
FULLTHROTTLE's Avatar
Default Re: need help and advise on engine.. (Dragproject-EG9)
Lighten the rotating assembly, ditch the VAFC and get Hondata or Neptune and tune it right.
Old Sep 4, 2005 | 10:11 AM
sorry im a lil dumb but what is the rotating assembly?
and hondata.. i want one but im kinda broke. any good deal for one?
Old Sep 5, 2005 | 07:33 AM
anyone?
Old Sep 7, 2005 | 05:37 PM
speedworks's Avatar
Default Re: (Dragproject-EG9)
no such thing as going fast on a budget
Old Sep 8, 2005 | 09:20 AM
sad.. anyone selling standalone ecu?
Old Sep 8, 2005 | 10:43 AM
.dave's Avatar
i HAS questions ?
Rotating assembly = crank, pistons, rods, whatnot.
Maybe try a lightened flywheel if you don't already have one.
Look into different intake manifolds as well. I know the AIR carbon fiber manifold has shown increases throughout most of the powerband but I'm not sure where you can get one from. It sure as hell won't be cheap though.
Neptune is the way to go for engine management. Where are you located?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">no such thing as going fast on a budget </TD></TR></TABLE>
So true.
Old Sep 8, 2005 | 11:10 AM
highendmike's Avatar
Multiple Accounts, banned multiple times
Default Re: (daveG)
the hondata s200 is a good idea. for more info on it go to http://www.hondata.com and if your on a budget check out http://www.bloxracing.com for a manifold.
Old Sep 9, 2005 | 12:25 PM
Default Re: (highendmike)
im already using a lighten flywheel i guess. it comes from the os twin plate clutch asmebly.. my mech has custom a throttle body and intake manifold combo. cos round 900. able to bored till max 90mm and still able to run on vafc without the need for a aftermarket ecu.. im saving up for it.. post pics once i have done it.. most probably take a long time hahaa..
Old Sep 9, 2005 | 12:26 PM
forget to add im from asia..
Old Sep 10, 2005 | 08:35 AM
asefi944's Avatar
Default Re: need help and advise on engine.. (FULLTHROTTLE)
hondata
Golding.racing
11
Sep 9, 2013 04:02 AM
fastlittlecivic69
Feb 2, 2010 02:44 PM
preludin
Jan 19, 2007 02:48 PM
HYBRIDSIRACCORD
Jul 14, 2004 09:29 PM
fred92htch
21
Nov 11, 2002 11:52 AM
