need advise first time to the track.
Old Apr 30, 2009 | 10:55 PM
jsw_1986's Avatar
Default need advise first time to the track.
So tomorrow we're hitting the track with my friends 630hp gsr. we have little to no experience when it comes to launching on slicks. They are 24.5 X 8 X 13". Any advise to what PSI yall run, and what you're launching at would be helpful and appreciated.
Old Apr 30, 2009 | 11:20 PM
ExospeedAMcrx's Avatar
Default Re: need advise
Start out at 8psi. Get used to how the slicks are first. If its spinning at 1st gear, lower the tire pressure 1/2 psi at a time until you find that sweet spot where its hooking just right. Takes practice to figure out whats best for your car, the track and your driving style.
As far as launch, try it at 8K. Each car/setup can be different a few hundred RPM. It also depends if you have a 2step or not. Where the RPM drops to, when you shift. How the slicks hook on the launch.
You'll figure all that out once you get some decent runs in and get used to how the car reacts and what it likes.
Good luck.
Old Apr 30, 2009 | 11:24 PM
jsw_1986's Avatar
Good luck.
Thanks man... Car is running s300 so it does have 2step and we're reving to around 8500-9k, but doesn't have a cage so I'm betting we're only gonna get in about 1 run before they tell us we gotta go. haha.
Old Apr 30, 2009 | 11:28 PM
Short shift it. Shift a few hundred RPM less than you usually do. Run slower times and focus on your launches this time out. Waste of time to get kicked out when you can be working on your launches with the slicks.
Old May 1, 2009 | 12:30 AM
FastEg6's Avatar
I would do the same thing Exospeed said, practice on your launching techniques and mess around with the tire pressure and 2step instead of going all out and trying to run some numbers and get kicked out without having any experience.
Old May 1, 2009 | 12:53 AM
1992Si's Avatar
Just a thought, do you have spare axles ?
Old May 1, 2009 | 03:19 AM
boostedcivicsir's Avatar
Mr. Badwrench
please choose a better title next time. il fix it for you. and search preloading.
AFAccord
Jun 25, 2014 04:30 PM
h2b_196_whp
Feb 23, 2014 05:18 AM
boostedteg4dr
Jan 3, 2013 03:44 AM
browniiiz
Nov 6, 2008 12:26 PM
EikoU
Nov 24, 2005 09:15 AM
