my first run time
Old Oct 4, 2004 | 07:31 AM
gillyfesh's Avatar
Default my first run time
i got a swap 94 eg hatch GSR motor gutted out no passenger and back sets, no carpet. just basic add ons adjustable fuel regulator, jun race ecu from ebay, act street clutch, short shifter, DC jdm headers and custom exhaust and i use street shitty tires (good year) w/ 29 psi. i think my car is still running kinda slow...
my first run time
R/T---- .131
60 ---- 2.345
330 --- 6.784
1/8 ---- 10.498
MPH --- 65.78
1000 --- 13.747
1/4 ---- 16.591
MPH --- 77.06
My second run time
R/T ----- .157
60 ------ 2.253
330 ---- 6.601
1/8 ---- 10.169
MPH ----69.60
1000 --- 13.251
1/4 ----- 15.862
MPH ---- 86.31
what should i do?? is this my final time for that swap???
need your feed back, thanks you!!
Old Oct 4, 2004 | 07:47 AM
Andres-eh2's Avatar
yes that is slow. "Seems like your granny shifting and not double clutching like your supposed to..." j/k
your mph is pretty low. I run better times in my LS powered hatch. Shift higher faster and get more seat time. You should be in the 14's no problem
Old Oct 4, 2004 | 07:51 AM
gillyfesh's Avatar
Default Re: (Andres-eh2)
dang forreal?? i guess i suck then hehehe....
i think my Vtec is not kickin in man?!? and my tach in off on out of calibration..
Old Oct 4, 2004 | 08:03 AM
Andres-eh2's Avatar
you probably didnt wire it up correctly
Old Oct 4, 2004 | 09:35 AM
94gsr4dr's Avatar
i ran a 15.1 at 91.5 in my stock full weight gsr SEDAN. Sounds like your car needs some lovin.
Old Oct 4, 2004 | 11:31 AM
JL's Avatar
JL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">I run better times in my LS powered hatch.</TD></TR></TABLE>
mine too, about a second quicker.
all it takes is practice man! don't get discouraged, i've run my car so many times down the track the first time i ever raced at the track i did very shitty and i just drove out discouraged.. but once i got back there and started having fun running times started coming down.. definately check your wiring.. if vtec isn't kicking in your car may have other problems that need to be addressed.
Old Oct 10, 2004 | 07:17 PM
gillyfesh's Avatar
Default Re: (JL)
ok i checked my car like the timing, it was 15 degrees advance. i lower the timing to 10 degrees and adjust my fuel regulator to 40 psi. am i doin it right?? please let me know. thank you!!
Old Oct 10, 2004 | 08:54 PM
gritsak's Avatar
Default Re: (gillyfesh)
thats really bad times...your 60' time isnt horrible but your MPH is really slow for your setup. my friend with a similar setup with less mods trapped at 99mph. ide check out your motor and see whats going on and maybe try running it without the ebay jun ecu
Old Oct 11, 2004 | 07:29 AM
dunkd's Avatar
might want to make sure ur getting full throttle
Old Oct 11, 2004 | 08:19 PM
gillyfesh's Avatar
Default Re: (dunkd)
im using the stock trotle cable from my hatch, is this okie??
Old Oct 11, 2004 | 08:20 PM
gillyfesh's Avatar
but not the trotle cable from integra gsr
Old Oct 11, 2004 | 08:23 PM
dunkd's Avatar
just have a buddy look when u press the pedal all the way down and make sure the part that the throttle cable attaches too spins all the way around
Old Oct 12, 2004 | 04:17 AM
kikeh22's Avatar
Thats what it is....check your wiring ...I had the same problem with a frankie
Old Oct 12, 2004 | 07:22 PM
gillyfesh's Avatar
Default Re: (****h22)
aite i fixed my tach meter, now it idles better, before it was 1500 and my red line was passing 10,000 rpm mybe coz i cut the two wires that attaches to the back of the AUTOMETER tach (green and brown wire) that i bought. now i connected one wire which is the brown wire and the idle droped at 700-800.
i took it for a test drive and the vtec kicked in @ 5800 rpm.. man i tell you my freakin car pulls like crazy!
theres IMPORT WARS this coming Sunday OCT. 17 @ Greatlakes raceaway and im gonna see what my time gonna be so wish me luck guys
thanks for the help
oh yeah by the way..! how many degrees should i adjust my timing at?? and how many psi should i set my fuel regulator at?? please let me know thanks!!!
Old Oct 13, 2004 | 06:02 AM
91civicDXdude's Avatar
set timing at 16-18 BTDC. set the FPR with specs in the manual. Usually its about 40-45psi with the hose disconnected.
Old Oct 13, 2004 | 04:33 PM
gillyfesh's Avatar
Default Re: (91civicDXdude)
why so high?? 16-18??? dang i think my timing is off coz the highest my distributor go is 15. hmmm imma double check it..
Old Oct 13, 2004 | 07:12 PM
africanqueen's Avatar
Seems a lil low to me. I hit 14.8 on shitty *** street tires with the GSR I had.
TwistedSI
24
Apr 12, 2003 09:59 PM
stevel
Jun 2, 2002 08:29 PM
B18poweredhatch
Feb 24, 2002 06:33 PM
mikeSONICGSR
Nov 5, 2001 07:02 PM
