msd digital 2 step rig up????
Old Jan 28, 2008 | 10:17 AM
boostede46's Avatar
Default msd digital 2 step rig up????
hello my fellow honda tech fanatics!! just got my car fixed due to my ignition coil blowing out....i hooked up my digital 6 box everything is working fine...but now i want to use its full potential.... so my question is how would i hook up my or rig up the blue wire from the msd box to a 12v source??
i kinda wanted to go with the clutch switch method but dont know how to do it...i know where the clutch switch is (under clutch pedal, has 2 wires coming out, blue/black one and a plain black one). i tried tapping into the blue/black wire but no power there...
i dont have cruise control so i dont think i have the other clutch switch (pink and black wire)....
so does n e body know what i need to do for this thing to work??
i also was thinking about hooking up to my left button horn, but i know the horn wire is a ground wire not a positive one....can n e body show me or tell me how i can hook it up?? i wanted the left button for the two step and the right button to act normal (beep beep).
so please help me out.... i did buy a momentary switch but i wanted a stock look...
lmk guys...thanks!!-justin
Old Jan 28, 2008 | 10:25 AM
logg_frogg's Avatar
Default Re: msd digital 2 step rig up???? (boostede46)
Usually people set their two step up with the neutral safety switch on the clutch pedal. Hence the name *two step* meaning two feet on the pedals.
I don't know the exact wiring schematics for an MSD setup but soemone else on here will probably be able to contribute a little more info.
Old Jan 28, 2008 | 02:26 PM
boostede46's Avatar
n e body els got n e ideas???
Old Jan 28, 2008 | 02:47 PM
jj07's Avatar
OG Fabricator
Default Re: (boostede46)
use the nuetral saftey switch. cut the wires that go into it with enough room to attach that plug to new wires. on the harness side of the wire you just cut solder them together(be careful now because that disables the clutch switch when you start your car). on the switch side solder that blue wire on the MSD box to one wire and the other to ground and you are done.
boostede46
Mar 7, 2008 05:51 PM
BoOsTiN Dc2
Dec 17, 2005 02:33 PM
underpressure02
Dec 22, 2003 04:11 PM
fastludeh22
Apr 22, 2003 01:31 PM
