msd 2 step
Old Aug 4, 2003 | 01:13 PM
JBk24crx's Avatar
Default msd 2 step 87crx
i have the msd 6al will this work or do i need another ignition box. thanks for the help.i realy need help installing this before i go to the track on my 87crx lsvtec. can anyone help me out on how to install it on my crx. I realy need your help on this one honda-tech.all i know is that you plug in the 2 step into the box and the black on to the chassis. where do the other wires go to.
Modified by rub760 at 7:51 AM 8/5/2003
Old Aug 4, 2003 | 01:21 PM
GSRswapandslow
Guest
Posts: n/a
it plugs into a 6al
i have one for sale
Old Aug 4, 2003 | 01:31 PM
hybridreams's Avatar
Default Re: msd 2 step (rub760)
The Digital 6 is the ignition box that comes with the 2 Step built in.
6AL will require a separate module to be purchased.
Old Aug 4, 2003 | 02:08 PM
JBk24crx's Avatar
Default Re: (GSRswapandbanned)
hey (GSRswapandbanned) does it require any mods. becuase the manual that came with the 2 step doesnt show the wires for a 6al what will i have to do to make it work.
Old Aug 4, 2003 | 07:26 PM
SpdFrk's Avatar
Default Re: msd 2 step (hybridreams)
Does the digital 6-plus come with the 2-step or just a plug in adapter so that later u can buy the 2-step module and plug it in?Also
Also what a good ignition system to buy? I want something with a 2-step. This is for a 00 turbo si.
Old Aug 4, 2003 | 08:40 PM
Default Re: msd 2 step (SpdFrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">Does the digital 6-plus come with the 2-step or just a plug in adapter so that later u can buy the 2-step module and plug it in?Also
Also what a good ignition system to buy? I want something with a 2-step. This is for a 00 turbo si. </TD></TR></TABLE>
Digital 6 comes with the 2 step built in. The ignition box itself has all of the dials to set your rpms, retard, etc. on it's side.
Although you hear of a few bad apples, there are just that many more people out there with successful MSD products that don't feel the need to post and complain about it. Not to mention MSD's technical support forum is OUTSTANDING.
I went with the Digital 6 and I recommend it. If you were to get the 6AL, you'd have to buy an additional 2 step module and preset pills for what rpms you want your limits set at. Check out MSD's homepage for more detailed info. You may also want to post on their Tech forum with any other MSD specific questions.
Old Aug 5, 2003 | 04:32 PM
GSRswapandslow
Guest
Posts: n/a
all you do with the 2 step is plug it into the revlimiter slot on the 6al. then plug your rev limiter one on the second slot of the 2step..and the pill at which you want to studdder at in the first one.
the either make a ground interuppt switch or a power one off of the power and ground wires that are coming out of the two step
rick_rabies
Aug 4, 2009 10:02 AM
EH6TunerDaniel
Texas -OK -LA (Sales)
May 1, 2009 04:41 AM
fastforwardracer
Apr 11, 2007 05:16 AM
