Miller
The secret is VTEC. A hydraulically actuated variable valve lift valvetrain designed almost 20 years ago...
Nice vette BTW!
pretty sure millers car and most of the outlaw cars have the vtec function disabled/deleted....... just sayin. so vtec isnt really the "secret". it allows the use of a eco/mpg/emissions friendly small cam lobe for lower rpms and a larger more aggressive lobe for higher rpm/throttle for more power when needed. oh, and i believe it was designed well over 20 years ago..... early or mid 80's if my memory serves me correct, it was actually intended for use on motorcycle engines
I think that was a little bit of an exaggeration lol. Maybe Not the 10k rpm part but the 60lbs (maybe not on millers car tho)
If u buy the right parts Hondas can go quite fast (faster then most people think). Alot like you have done for your Vette. Simple but efficient parts can go a long way.
Ok ok, so VTEC isnt the secret....
The real secret is that is the front wheel drive...shhhh, lets not give away all our tricks
Something about its easier to "pull" than it is to "push"...
Don't mind at all.
Stock LS2 block 364cc
Stock crank
Dry Sump
Forged Rods, pistons
Trick Flow heads
Stock intake & TB
Stock ECM
1 3/4" LT headers, muffer rear exit exhaust
Paxton Novi 2500 SC
Air to Air innercooler
Power glide trans
IRS
(Street Legal)
Motor built & tuned by East Coast Supercharging NJ.
Stock crank
Dry Sump
Trick Flow heads
Stock intake & TB
Stock ECM
Paxton Novi 2500 SC
Power glide trans
IRS
(Street Legal)
LS based engines can and will straight up roll out!!!
An old friend built a LS turbo setup. It was alot crazier than this setup and made a TON of power. Full street car with all the additions, a/c, p/s, leather, the works. He drove it alot, and ended up selling it to someone out in Colorado. They flew over bought the car and drove it back to Colorado from NC. That same week they took it to the track the exact way they drove it over and went 9's @ 160 mph. It was still a 6 speed car.
Anyways, enough rambling. I thought the call-out on the back of the car was cool. Maybe I will see you around racing more.........Good luck with your car!!
