----May FS Thread----
This is a project that I have not had time to work on in the past two years. Between beginning another business, building and finishing another project that I have dedicated more time to, and now buying a new house I have to sacrifice something. As much as I would love to finish the project, I just don't have time. I will post pics of parts as I take them. Give me a call if interested. This is the best way to reach me 301-992-2223.
ERL Bottom end with Justice Race Engine Head
84mm bore, Crower billet rods, ERL 5 stud girdle, Coated bearings, ARP Mains, Ported Head, Ferrea Valvetrain, Skunk 2 Pro 1 cams. Motor has not been ran since assymbly.
Asking $5700
Hasport Billet Mounts w/ billet inserts $350
NRG Fuel Cell $400
T1 Catch Can $200
Full-Race Turbo Manifold $1000
Chase Bays Milspec Harness w/ T1 cam trigger kit and M&W ignition integrated $1700
Golden eagle scatter shield $175
Asking $5700
NRG Fuel Cell $400
T1 Catch Can $200
AEM EMS 1050 box currently set up for T1 cam trigger but can be easily switch for stock distributor. $600.00
American racing 15X9 4X100 wheels with holes for rim screws. $400.00
A2W setup Bell inter cooler core, water box that fits in EK engine bay with internal water pump and lines. $600.00
selling myT4 .96AR jb pt6768 off my car...has about 15 track passes on it and dyno time...made 887hp on it....if intrested u can reach me at 305-281-6495 ryan $1300
aem cam gears...80
port/polish h22 Head fresh out the machine shop... 1300
3 angle valve job
DH racing valve springs retainer
stock valves
new oem valve seals
powder coated gunmetal valve cover
New RMF replica Headers(modified for h2b)...400
h22 block/h23 crank.... 2200
sleeved,88mm wiesco 13:1 pistons with new rings h23 95mm std crank micropolish and balance crank acl rod bearings clevite mains SGI h-beam rods
h23 single crank pulley
new oem oil pump/rear main seal
balancer shaft deleted
aem cam gears...80
3 angle valve job
stock valves
new oem valve seals
AEM 3.5 Bar Map Sensor, Stainless Steel used but in great condition. AEM part number 30-2130-50. retails for $150+
Asking $75 shipped. PM me with any questions. Thanks!
RLZ 290+ cfm CNC Street port 2000 b16 head
Ferrea 5000 series standard size valves
Ferrea springs and retainers s10027 springs, e11000 retainers.
New valve stems and seals
Will not include intake manifold or throttle body, or ARP hardware
Will include vtec solenoid
$1250
head is 250, valves are 200, springs and retainers are 500, port work is 800. Save yourself $500+ and a wait of 1-2 months.
Toda Spec C intake and exhaust cams - no explanation needed, great midrange, good top end power.
$550
Toda cam gears, anodized black by CCW. These were brand new, I had them anodized by CCW (thanks Wray). I am asking less than they go for brand new from JHP and the anodizing was $75
$300
Edelbrock performer X manifold, bought brand new, had it shaved, powdercoated satin black
$250
Aem FPR black AEM Fuel Rail Black
$100, $80
All In Fabrication B series tuck radiator, custom anodized black by CCW(thanks again Wray)
Dual fan option with shroud
Custom filler neck for b16/itr and thermostat outlet for -16an
-16an black coolant lines with black fittings
$750 this setup cost Radiator $425, Fans/shroud $125, Fillerneck on head $65, thermostat housing mod $25, Fittings/hose kit $170, plus the anodizing which was $150. This is a complete set up that will work in an integra, 92-95 or 96-00 civic.
ACT xtreme pp
2 act 6 puck unsprung disc
Fidanza flywheel
$190 both discs are used, but still have 7-10k miles on them if you dont drive like a jackass. You can buy a brand new disc for $100ish and still have a complete setup with spares for under 300. pressure plate and fw are in great shape.
$1250
$550
$300
$250
$100, $80
ACT xtreme pp
Fidanza flywheel
Edelbrock VictorX ported 72mm
Includes:
Blox 72mm billet tb
TPS
MAP Sensor
IAT Sensor
IAC
Ready for nitrous
$350
I will have the nitrous ports professionally welded and smoothed on inside of the runners if the buyer wants.
This was the old nitrous setup
Includes:
Blox 72mm billet tb
TPS
MAP Sensor
IAT Sensor
IAC
Ready for nitrous
$350
Full-race Honda s2000 turbo kit $2500obo
Manifold,pte6262turbo never used ,bov,wastegate,intercooler,piping,couplers,clamps & lines
Bnib cp flat top Honda s2000 pistons part# Sc7060A $550
Willing to do some trading for a pte7280 or 7285 turbo
text me @ 617-719-1781 do not pm me
everything is located in York, PA. local pickup preferred but i will ship some of the things at your expense. add 3% for paypal fees if paying me that way
best way to contact me is call/text, number is 443 eight4six 2511
81.5mm b18a1 block $1600
Manley H beams
Wiseco 9.8:1 pistons
ACL race bearings
ARP headstuds (for lsv)
new water pump
the block has 0 miles on it since i got it from the machine shop, it was bored/honed, rings gapped, crank was polished and measured.
when i assembled this motor, i plastigauged everything. Its all within spec, if you're serious i can pull a cap and do it in front of you to show you.
i also have everything to make it a running motor, starter, alternator, new distributor, shift linkage, axles, hoses, etc. if you need any of that just ask and i'll give you a price on that stuff
B16 head $600
supertech dual valvesprings (turbo)
supertech valve seals
brand new LMA's (beehive springs, not hydraulic)
fresh valve job, one valve was replaced
just resurfaced
comes complete with all cam caps in order
has 0 miles since i got it back from the machine shop
valve cover can be included
13" Lenso's with 24.5x9 MT ET Drags lots of passes left $450
i can include wheel spacers with them as well so they don't rub
fronts only
Forged Performance ramhorn manifold $450
mostly idle time and maybe 15 miles max
Holset HY35 turbo $200
will include downpipe and feed line adaptor for 4an line
F1 Spec type 2 seats $450
have 96-00 brackets
Crow Enterprises 5pt harness (brand new, expires in a few years) $60
bolt in style but can wrap around a cage
GSR cams $150
Golden Eagle fuel rail (brand new with all fittings) $100
Go Autoworks fuel lines, from stock filter to rail to regulator then to stock return (brand new) $125
Aeromotive Fuel Pressure Regulator (brand new) $125
Aeromotive Fuel Pressure Gauge (bnib) $20
Edelbrock Victor X intake manifold $225
Edelbrock Performer X throttle body 68mm i believe $275
aluminum radiator and slim fan $75
Allstar performance catchcan and oem block fittings, and some hose $70
Skunk2 dual bend short shifter and weighted **** $100
innovative motor mounts 70a bushings (stiffest poly bushing) $175
Progress Technology drag series coilovers 350/500 spring rates $500
Manley H beams
ACL race bearings
new water pump
B16 head $600
just resurfaced
fronts only
have 96-00 brackets
GSR cams $150
