----May FS Thread----
Old 05-01-2012, 06:51 AM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Default ----May FS Thread----
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
ahobbs is offline
Old 05-01-2012, 08:00 AM
WHTZ's Avatar
Default Re: ----May FS Thread----
FS: Danny Fab (DB) Sidewinder Turbo manifold T3 with downpipe $800. Flanged for a Tial 44mm or 46 Precision wastegate...
Manifold holds boost no problem till redline with '0' spiking
Never one time cracked
Tuned on a stock motor making 600+ tuned by Chris Treblic
10.49@ 140
WHTZ is offline
Old 05-01-2012, 09:46 AM
boosted hybrid's Avatar
Garrett 24x12x4.5" core with cast end tanks. Brand new. 1000 whp capable intercooler. End tanks are "blank" so you can put the inlet/outlet where you want. $650.00 shipped in the 48 states.
All prices are fair and firm. Shipping is included in 48 states. Paypal is preferred payment. Pm or email tech@evans-tuning.com.
boosted hybrid is offline
Old 05-01-2012, 09:47 AM
JonathonTheZombie's Avatar
FS: Used Garrett T4 T67 High Output Turbo. Purchased originally through Full-Race years ago.
Specifications as follows:
-T4
-Journal Bearing
-.70 A/R Compressor Housing
-.89 A/R Exhaust Housing w/VBand Exhast (Clamp not pictured but included)
-800-1K Miles (Mostly track use only)
-Compressor Housing Powder Coated Mirror Black (just done a couple weeks ago)
Price: 475.00 Shipped (within the 48 states)
More images available upon request!
Contact: Tyler @ 541-570-5071 or PM me.
JonathonTheZombie is offline
Old 05-01-2012, 11:28 AM
Themouse's Avatar
FS: Brand New FCS 5 Gallon fuel tank with in tank Dual walboro option($175 dollar option)-$575 obo
Themouse is offline
Old 05-01-2012, 01:16 PM
tuhboek's Avatar
I have a backdoor intercooler
It is a Precision fabbed up into a backdoor style intercooler.
Precision 750hp 31 1/2"L X 10 5/8"H X 3 1/2"D -$500
pm for more info or any ? you may have.
Thanks
tuhboek is offline
Old 05-01-2012, 02:05 PM
FRernesto's Avatar
A few items for sale, Prices negotiable.....
-Borg Warner turbin housing Twin scroll 1.10ar for S400SX 71mm turbo. 125.00 New never used!
-Injector resistor box plus OBD1 injector clips. (USED)35.00
-TiAL new 60mm inlet flange. (NEW)25.00
-35mm Exhaust flange plus gasket. (NEW)10.00
-MF2 Mappable Injector Driver can control either additional fuel injectors or water injection and 2bar map sensor. Instructions included (USED) Make an offer...
FRernesto is offline
Old 05-01-2012, 03:19 PM
SPOOLINmatt's Avatar
Honda NTK sensor for NGK Wideband and any others that accept it. used for a race.
$100 shipped
B18B Golden Eagle Block with Orings - 85mm
$800
DH Racing 69mm Billet Throttle Body - has been cut, had a Vanjen Quick connector on it...still great for that or Vband
$200 with TPS - $150 without TPS
$85 for magnaflow 4" race muffler
Set of 3 used Eagle rods - 5.430" length for B18C1 GSR Crank. $125
Set of 3 used manley rods - 5.430" length for B18C1 GSR Crank. $125
3.5" vanjen coupler setup
Clamp is slightly used
Flanges are brand new
706-346-6024
matt.stover@comcast.net
SPOOLINmatt is offline
Old 05-01-2012, 05:45 PM
jdm inc's Avatar
weld magnums 13x8 5" bs have been drilled for rim screw
$500
s372 standard cover- make offer
jdm inc is offline
Old 05-01-2012, 07:09 PM
Ls_dx's Avatar
2x 38mm black tial MVS gates with all springs
520 shipped/PayPal
competition clutch stage 4 ceramic b series hydro
BRAND NEW IN BOX 315 SHIPPED PAYPAL VERIFIED
Ls_dx is offline
Old 05-01-2012, 07:33 PM
Sickteg24's Avatar
Precision 1000cc injectors for sale, work perfect just don't need them anymore. Asking $210 shipped anywhere.
Sickteg24 is offline
Old 05-01-2012, 08:26 PM
Tyler H's Avatar
H22 Turbo Manifold - $700
Built by Innovative Turbo Sysytems back in 2003. Was fully polished, bead blasted now. T4 single scroll and two bolt 38mm wg flange. Thick wall stainless steel TIG welded construction. Very durable, been used on a street car for years. I'll include an adapter to run a 44mm v-band wg. Including downpipe too.
Precision Turbo 1000cc Injectors - $200
Used, but in excellent condition.
99-00 Carbon Fiber Hood with Custom Scoop for Full Race K24 manifold - $200
Tilton H22 Cerametallic Twin Disk Clutch - $1000
Less than 10 passes. Excellent condition. Had my machinist clean up the flywheel bolt mounting surface, it got a bit worn.
H22 CNC Ported Cylinder Head. Ported by R&D Dyno Service. - $600
Includes cam caps, rocker assemblies, shafts, LMAs, dual springs and Ti retainers. Intake #3 has full valve guides, all other ports are cut back to the port wall. I'd recommend getting new springs and retainers.
Sparco Steering Wheel with EK hub - $75
About six years old, leather pulling back a bit. Includes horn button.
Aeromotive ELIMINATOR 11104 Fuel Pump - $250
Slightly bent mounting ear. Fittings not included.
Tyler H is offline
Old 05-01-2012, 09:39 PM
JJsMotorsports's Avatar
This manifold has gone 8's
Twin 44mm will be needed,has back pressure port
will come with dump pipes and flanges
I'm giving this away at 600 shipped.......Vegas money! SOLD!!!!!
I also got a2w garrett core 1000hp rated with tank, and pump.....my old set up 500 you pay shipping........SOLD!!!!
210-214-8542
S300 V1 with pins and data cable 265.00 shipped! Sold!!!!!!
Max
JJsMotorsports is offline
Old 05-01-2012, 10:20 PM
EDLOVA23's Avatar
IF INTERESTED CALL 973)390-2982
B-series shift linkage with a B16 shifter*
4" aluminum exhaust $650
custom catch can sits next to the battery $275
the bracket is welded onto the battery tray*
comes with
battery tray w/ bracket welded to it
all 4 lines and fittings minus the 2 fittins on the actual block
EDLOVA23 is offline
Old 05-01-2012, 11:46 PM
tenthelementracing.com's Avatar
For Sale:
Precision Turbo GT4272R Turbo, 15 passes on it. $2500 OBO plus shipping.
Pm me if interested.
tenthelementracing.com is offline
Old 05-02-2012, 03:32 AM
sik9sec's Avatar
set of bogart pro 4s..15x10 up front w 26" m/t w 7 hits n rears are 26'' also.... right now wheels are matte black but can have them repolished...
1200.
sik9sec is offline
Old 05-02-2012, 05:09 AM
IMPORTMyth01's Avatar
96 Acura Integra GSR Weekend/Track Shell
Clean and Clear Title in Hand in my Name
Up for sale is the Integra I have been working on for the last two years. Car was completely stock with a bad motor and I stripped it down to nothing and removed all the PS, AC, ABS, etc and rewired the entire car with a OBD1 harness and RS brake lines, etc. then put it all back together with the below mods. Car was meant to be my weekend warrior for Autocross and Drag but 8 months after it was in its prime the motor let go due to a bad vacuum line.
My wife just gave birth and I thought I would be able to juggle getting the car up and running again but no bueno. Would rather sell it now so that it doesn't deteriorate. Car has been kept under a car cover for the last year or so and still in the shape it was the day at the track the motor blew.
Willing to take $3300 cash with electronics still in car as is, $2800 without them.
Car will come with 4 matching 16" No name black wheels with a polished lip.
Only trade would be a 92+ Civic Sedan or 94+ Integra sedan with AC and 5 speed and in good shape
Contact me 706-577-3364 Call/Text with any offers
Below is the link to the entire picture gallery (didn't want to crowd the whole page with photos)
http://s128.photobucket.com/albums/p...0Sale/Integra/
Exterior:
Flat Black to mimic Black Anodized
VIS Carbon Hood w/ Sparco Hood Pins
VIS Carbon Hatch with FAl Glass (cracked but still functional)
Mugen Front Lip (Front Bumper could use replacing)
35% Tint
Interior:
Autopower 8 Point Bolt in Cage
Mint Del Sol Seats
RCI 5 Point Harness (4 mounted I have 5th belt)
JDM GSR gauge Cluster
Air Bag Delete
JVC Head Unit
Engine Bay:
Mild Wire Tuck
Battery Located in rear
ABS Removed
PS and AC removed
Suspension:
Drilled and Slotted Rotors
Function and Form F2 Suspension Custom Eibach Springs 20K R and 14k F
Skunk2 Rear lower Tie Bar
ELD Front Traction Bar
Energy Suspension Rear Trailing arm bushings
Upper Rear Strut Tower Bar
Skunk2 Front Upper Control Arms
Electronics:
Advanced Alarm and Theft Deterrent System
Greddy Profec B Boost Controller
Greddy Turbo Timer
PLX RX500 Wide Band
Glowshift Boost Gauge
Glowshift Oil Pressure Gauge
Glowshift Shift Light
Ebay Steering Wheel
Complete LS Block w/Skunk2 Manifold $500
Fresh Rebuild with 0 Miles, comes with Alternator (OBD2), Distributor(OBD1), Sensors
IMPORTMyth01 is offline
Old 05-02-2012, 07:34 AM
RASE's Avatar
Weld Magnum 15x3.5 spindle mount wheels w/ Hoosier 23x4.5x15 Drag Front Tires:
Wheels are powder coated silver (original finish was gold) and will likely need to be redone. The wheels themselves are in excellent condition. They are, however, missing the center caps which can be purchased directly from Weld Racing. The tires have 22 passes on them, they still have plenty of life left on them.
Asking $500 for the wheels with tires mounted (will not separate).
H22A4 Shortblock:
2001 H22A4 Shortblock. The block was attained from a Honda dealership in 2001. It was a warranty exchange on a new prelude that had a blown head gasket. Coolant leaked into one of the cylinders. The block just needs a simple bore/hone and its good to go. It comes with main caps, main studs and main girdle. I've had it for over a decade and unfortunately, I never got around to using it.
Asking $350 ($450 with the crankshaft)
2001 H22A4 Crankshaft:
This crankshaft came out of the block I am selling. It is in excellent condition, no journal imperfections at all. It has been stored properly for as long as I've had it. It just needs to be micro-polished and it's good to go.
Asking $150 ($450 with the block)
H22 Fluidampr Harmonic Damper:
Used, but in great condition.. It kissed the radius rods once which left surface scrapes on the outer edge, but other than that, its perfect for use on another built H/F.
Asking $200
All prices are + shipping.
PM me if you are interested.
RASE is offline
Old 05-02-2012, 07:52 AM
200 HP's Avatar
Delete
200 HP is offline
Old 05-02-2012, 07:55 AM
B100sst's Avatar
Precision 1600cc injectors & fjo injector driver 350$ came out of a perfectly running car.203-278-2806txt fast response
B100sst is offline
Old 05-02-2012, 10:17 AM
DC2_117's Avatar
I have a few parts for sale. Please PM or email me for more info. Thanks
Tony1 T1 Race Development GT1 Intercooler, goes for $1399 on their site plus it has to be made. Get this one for $950 shipped!
AEM Twin Fire ignition w/ harness $250 shipped
AEM 4-Channel K-Type Thermocouple Amplifier brand new pics tonight
$225 shipped
DC2_117 is offline
Old 05-02-2012, 12:03 PM
OG Fabricator
jj07's Avatar
TODA B series flywheel brand new been sitting around for a little while, now going Kseires $350
Garrett Air to Water core 4.8x4.8x12 1000hp also brand new $270
jj07 is offline
Old 05-02-2012, 01:25 PM
dturbocivic's Avatar
Acura Integra race chassis 5750.00
this is pretty much a shell at this point. i bought the car, added a few things and never got to run it.
* 10 pt chromoly cage
*Jojo wide front end (closed mouth) mounted with tubular frame & dzues buttons
* custom aluminum under body tray/catch pan, with quick release mounts
* carbon hood and carbon trunk --color matched
* gas tank has full race sump installed
lines/fittings for water to air intercooler
* 12an fittings on tank & intercooler
* 3/4 shut off valve on tank for drain
* hose is 3/4 inch
85.00 shipped
* eibach front and rear sway bar kit with endlinks etc, i belive its everything for installation. 250.00
__________________________________________________ _______
skunk2 stage 2 cams for b series -- best offer
fiberglass doors for 92-95 civic coupe 650.00
carbon fiber 1 piece nose for 92-95 civic 500.00
pro topline - RHS gsr cyl head, fully built by Ed's racing heads / Headgames, ferrea valvetrain, custom springs, have 3500 into head, willing to sell for 2500.00
weld magnum spindle mount skinnies(strange spindle) with wheels are brand new, used for mock up includes brand new tires -- 1200.00
JMF intake manifold for gsr head (setup for 12 injectors) 750.00 obo
* OMC coils (coil on plug) with bracket
- fits b series vtec heads
225.00 + shipping
Golden Eagle Manufacturing block girdle (brand new in box) 300.00 shipped
AEBS main stud kit 100.00 shipped
Golden Eagle MFG main stud kit 100.00 shipped
Motec m4,6,800 wiring harness setup for b series 1000.00 OBO setup for 12 injectors, emap, fuel psi, strain gage.
jmf/spearco water to air intercooler. 4 v-band inch inlet/outlet. -12 an male bungs for water connection, good for 1000hp 500.00
jmf 2 gallon fuel cell -12an outlet, -6an return 350.00
jaz pro stock 2 gallon fuel cell 200.00
cnc master cyl with mounting bracket (fits civic + integra) 150.00
3 b series vtec solenoids 50.00 each
2 sets of b series rocker arms with shaft 100.00 set
2 sets of b series lma's 50/ set
stock gsr valves/springs/retainers/locks 100.00
b series transmission parts/gearsets/bellhousings/gear housings- let me know what u need and we can work out a number.
more detailed pics/description click here
vibrant pn12548 vanjen weld ferrules 40/set
pegasus 4inch clamps(black) 40/clamp (no weld ferrules, fits wiggins/hydraflow ferrules)
black integra dash- best offer
integra rear filler panel(under tail lights) best offer
d16z6 long block with wiring harness/ dist/ ecu 350.00
d16y8 cyl head 150.00
d16z6 intake manifold with throttle body/injectors/fuel rail 100.00
d16z6 auto harness 75.00
d16z6 auto trans - best offer
d16y8 auto trans- best offer
http://i240.photobucket.com/albums/f...5992966614.jpg
92-95 civic ex cluster- best offer
dturbocivic is offline
Old 05-02-2012, 06:35 PM
GT40eg's Avatar
Full-race dual back door intercooler $600
Full-race polished intake manifold w/72mm BDL throttle body GSR $750
Full-blown dual pump hangar $250
Full-race twin scroll top mount twin 44s $1050
3”to 4” downpipe to go with manifold $250
LS crank $100
Magnafuel fuel pressure regulator $80
Ported GSR head no valvetrain $800
BC stage 3 cams $350
Supertech full valvetrain $650
Weld skinnies polished with tires $1000
Morso 5.5 quart oil pan $300
Ferrea cams/rockers/t1 block off plate $1400
4” exhaust with vibrant muffer $350
ID 2000cc injectors $800
Golden eagle intake manifold gasket GSR $40
GT40eg is offline
Old 05-02-2012, 06:40 PM
dyno76's Avatar
Spinwerks Brand new never mounted still in boxes!
fronts 13x8 $500 includes shipping and paypal fees
rears 15 x 3.5 are SOLD
I am verified and can supply plebty vouches
dyno76 is offline
Quick Reply: ----May FS Thread----
