map sensor help!!!!
Alright guys I need some help I recently did a little change up on my car before it ran perfect... I went from stock tank, walbro 255, aeromotive a1000 pump on the firewall, and hondata 4bar map, to fuel cell, just aeromotive a1000, achange aem 5bar map
I changed map sensor just bc it screws in over having a vacuum line. So my question is on a s300 what do you set the map as in the ecu? User it as 5bar and my car wont go past 4500 why would this be and what can I do to fix it
something else may be going on, but for what its worth, my car DID NOT like being installed in the engine. i put a nipple on it, and ran a vac line.
so you do have the s300 set to read the 5 bar?
