ls-vtec question on piston choice?
Old Sep 26, 2003 | 02:45 PM
spoon23_JDizM AkA SpOoN20's Avatar
Default ls-vtec question on piston choice?
running first gen b16 head,what piston can i use that will put me on the border right below having to use race gas,and still be at 91.
Old Sep 26, 2003 | 08:00 PM
kill bill's Avatar
Default Re: ls-vtec question on piston choice? (spoon20)
b16 or itr pistons. i say go for the gusto and mix a lil 100 with your 91 and use the ctr pistons
Old Sep 26, 2003 | 10:32 PM
allmtr's Avatar
i used ctr pistons and had about 12.3:1 compression. 91 was fine for me with tuning and retarded timing.
Old Sep 27, 2003 | 02:26 AM
97lsvtec's Avatar
ctr piston is a good piston to use
Old Sep 27, 2003 | 02:48 PM
Triple T's Avatar
Default Re: ls-vtec question on piston choice? (i need space)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i need space &raquo;</TD></TR><TR><TD CLASS="quote">b16 or itr pistons. i say go for the gusto and mix a lil 100 with your 91 and use the ctr pistons </TD></TR></TABLE>
I have jdm r pistons and for the break in period i mixed 100 with 91. Gas is so damn expensive so I said crunk that and ran just 91. It runs fine with no knock or detination so I would vote for jdm ITR pistons.
Old Sep 27, 2003 | 08:39 PM
camp1320.com's Avatar
ITR and PR3 SI-R pistons is the most commonly used. Some do run CTR with retard timming on pump gas and get it not to knock or ping. To be on the safe side go ITR or Si-R.
Old Sep 28, 2003 | 11:31 AM
Default Re: ls-vtec question on piston choice? (camp1320.com)
but ctr piston will be fine tho.
Old Sep 29, 2003 | 05:45 AM
00 FBP ItR's Avatar
you can run ctr but you'll need to retard the timing as Tom(Camp1320) said, which would also "retard" the performance of your motor. So it won't be putting out its best.
Old Sep 29, 2003 | 08:31 AM
sander's Avatar
2.7(p/t)
Default Re: ls-vtec question on piston choice? (00 FBP ItR)
depends on where you live, im in maryland, we have 93 everwhere here. i have my timing retarted just a degree or two and i dont have a problem with CTR. infact i like them quite a bit.
-sander
Old Sep 29, 2003 | 11:07 AM
Default Re: ls-vtec question on piston choice? (sander)
well than will a jdm itr piston be a ok piston for the set-up.
Old Sep 29, 2003 | 12:19 PM
Benny Hinn's Avatar
I would go lightweight with some forged pistons.
I do have a set of JDM ITR pistons oversize if you decide you need them.
Old Sep 29, 2003 | 01:11 PM
CHEETAH's Avatar
Endyn rollerwave pistons is what you're seeking, a mild dome 81.5mm dome will be fine with 91 octane and 14 deg timing, race fuel dump the bitch to 18/19 degrees timing. Use one of my ecu programs for best results. I can even put a switch in the euc for you to switch programs on for racing and off for stock if its a 92/95 ecu.
Greg
milruner
Jan 20, 2005 07:06 PM
Jmorin
12
May 29, 2004 02:30 PM
toohott4handlin
Jan 19, 2004 05:21 PM
unsurpassedLS
May 7, 2002 07:34 PM
