liberty cuff
Old May 7, 2011 | 11:53 AM
sanman000719's Avatar
Default liberty cuff
anyone have the instructions on how to do this its all ripped apart, and i just wanna be sure im correct
Old May 7, 2011 | 11:59 AM
redboost10's Avatar
Default Re: liberty cuff
they usualy send it with the washers ziptied on top and bottom of the bearings and thats how you install it.
Old May 7, 2011 | 12:10 PM
ok yeah i got that and your right im looking for the instruction on pulling the gears and setting the cuff on the main and counter shafts
i got this second hand off here, and im a stickler for doing it right rather than just trying to figure it out
Old May 7, 2011 | 02:06 PM
SPOOLINmatt's Avatar
uhh mine was sent with both washers on bottom. if you put it together and lift the countershaft...and something looks funny. you know its not right.
Old May 7, 2011 | 02:23 PM
ok they are ziptied to the part of the cuff that goes on the countershaft
what i am trying to understand is exactly step by step how to get this thing on from what to remove to what to keep on
maybe i was a little vague in what i asked, but is there actual instruction from pulling what need to be pulled off both shafts to what needs to be kept
Old May 7, 2011 | 02:27 PM
remove the 5th gears....remove anything BELOW the 5-r slider hub....brass stuff, etc....and leave everything below the gear. I would advise finding something to drop down into the 5-r input selector hole to keep the slider cuff from touching the liberty cuff and getting aluminum shavings in your tranny....happened to me...im sure it happens a lot.
Old May 7, 2011 | 02:32 PM
redboost10's Avatar
bought mine a long time ago...couldnt really remember if washers were on top or bottom. i just remember they send it to you ziptied how they want it installed.
before putting it in the car, make sure it feels right on the bench. if you read some old threads, youll see that sometimes there have been clearance issues with these cuffs.
edit: spoolinmatt beat me to it...be careful with the 5-r slider rubbing on the cuff
Old May 7, 2011 | 02:42 PM
sweet thanx guys
JDMCRX
10
Dec 15, 2007 10:02 AM
Horatio
17
Jul 17, 2003 12:56 PM
boomslang
Oct 24, 2002 04:29 PM
boomslang
Oct 7, 2002 08:17 PM
Mad DSM
Jul 20, 2002 05:47 PM
