liberty bullhousing
#28
Re: liberty bullhousing
I need somebody to please pm me EVERYTHING that needs to be modified to run the liberty case...
Iam running a spool..tilton bearing..and magnus gears. On the limit right now!!!
#29
If the material wasnt so expensive, we would make one. We have access too a full CNC shop.The material was close too 1200, cheaper too buy one from liberty after you consider time.
#32
Thats all that should need to be done.
#35
that is correct the housing arent much profit. we have a engineer is very meticulous about clearances which is getting quite annoying. but he definitely has some cool ideas to make things better. he laughed at the liberty case if that tells you anything.
#36
If he laughed at the liberty, then I'm really interested to see what he comes up with. The outer case half is really needed as well.
#39
#40
#44
Liberty is repairing our case, and all of the newer cases will already have more material in this area, as well as having clearance for the slave cylinder, differential, and flywheel.. They really seem to want to improve the product, which is good news for us!
#46
Showing you where to clearance the case for the flywheel bolts is only going to get you so far. Your still going to stab the tranny a few times before knowing when enough is enough. Simply meaning that you don't want to remove too much material, so your going to grind and check it a few times til you get it right. I think we put the tranny in about six times on the first one before "trusting" yourself to only do it twice on the second one lol.
#47
Are these only for B-series, or are there some K-series too?
Is this what Miller is using, or he is just selling them?
Thread seems kinda all over the place. Who are the vendors for these things?
If there isn't a vendor, then who are the 'competitors' that offer other bell housings?
#48
JK
