Lexans windows
Old Mar 15, 2010 | 01:00 AM
turb0teg's Avatar
Default Lexans windows
Did a quick search with no results. Can lexan be set on top of the factory window, then both slowly heated in a large oven to form the shape? Obviously it'd be a little bit larger, but would the basic shape be the same and would it work?
Thanks
Old Mar 15, 2010 | 04:26 AM
redzcstandardhatch's Avatar
something different
Default Re: Lexans windows
technically, yes. the "drape" temperature of polycarbonate (lexan is a name brand, technically, there are several others) is roughly 350 degrees... you can get factory tempered glass that hot, but not instantly. slow heat=no problem.
its very do-able, but you need absolute patience, a good heat gun ,and a big oven of some sort.
Old Mar 15, 2010 | 06:17 AM
grand champ's Avatar
Def don't heat the glass to fast or you'll end up with more than one piece. The lexan is pretty flexible though. unless your doing it for the look its really not necessary.
Old Mar 15, 2010 | 09:34 AM
ptftw's Avatar
youre not fast enough for lexan fool
Old Mar 15, 2010 | 06:09 PM
turb0teg's Avatar
Seems reasonably easy, with patience like you mentioned. I'm very concerned with the window looking flat and not molded. I know it won't look like a factory glass window, but molded is 100x better IMO
Nobody said I NEED lexan. I want to lighten the car.
Old Mar 16, 2010 | 03:47 AM
something different
i am working on molding lexan within a week. what kind do you need (what car?). PM me, i might be able to hook you up
EdWord
15
Dec 10, 2009 09:44 PM
8atman
Jun 8, 2006 05:48 PM
92ehatch
Nov 1, 2005 06:16 PM
Kwayzie
May 28, 2004 06:41 PM
Neeko
May 2, 2002 02:28 AM
