Lexan windshield bracing
Old Sep 15, 2005 | 03:36 AM
k-series's Avatar
Default Lexan windshield bracing
I've seen 1 and 2 bar/strap set ups from various pics online. However, how are they attached in the car? Are the bolted or welded in and to where (what points)?
A few pics or links would be really helpful.
Thanks!
Steve
Old Sep 15, 2005 | 04:09 AM
DaveF's Avatar
Default Re: Lexan windshield bracing (k-series)
use 1/4 inch tubing, weld it to the cage at the top of the windsheild, and along the bottom, weld it to the sheetmetal.
in this picture, there is a small tab welded onto the sheetmetal, the dash slides under it, and the windshield tube gets welded to the topside.
Old Sep 15, 2005 | 04:37 AM
k-series's Avatar
Default Re: Lexan windshield bracing (Dturbocivic)
Awesome info, thanks! I won't have a dash so the install should be pretty easy.
How did you determine the curvature of the tube or did you just use trial and error?
Thanks again!
Steve
Old Sep 15, 2005 | 04:57 AM
DaveF's Avatar
if you have your piece of lexan, you can put that in. then look "across" the windsheild, and position the support so there are no "dips" in the lexan.
Old Sep 15, 2005 | 05:01 AM
k-series's Avatar
Excellent, thanks again!
Steve
Old Sep 15, 2005 | 10:57 AM
msmotorsports's Avatar
You may want to weld tabs on the cage and bolt the support instead of just welding the support directly to the cage. You never know when you will want to remove the support.
Old Sep 15, 2005 | 11:00 AM
k-series's Avatar
Default Re: Lexan windshield bracing (msmotorsports)
I was hoping I could do that. A lot easier to adjust and to remove.
Thanks!
Steve
Old Sep 15, 2005 | 06:18 PM
LSR-Abuser's Avatar
[QUOTE=msmotorsports]You may want to weld tabs on the cage and bolt the support instead of just welding the support directly to the cage. You never know when you will want to remove the support.[/QUOTE
Thats what i did.my dash was made to go though the front window olny.
92Snatch
Jan 3, 2016 08:46 AM
Rob!
May 14, 2006 10:14 PM
16vt
Welding / Fabrication
30
Jun 16, 2005 09:38 AM
sidoe
Audio / Security / Video
10
Nov 20, 2001 10:33 AM
