Lcd Install??
Old Nov 19, 2001 | 10:44 AM
sidoe's Avatar
Default Lcd Install??
I just recieved a 5.6 inch in dash lcd i'm wondering how I can go about securing it what brackets etc I should use?
Old Nov 19, 2001 | 07:25 PM
sidoe's Avatar
Default Re: Lcd Install?? (sidoe)
Can you guys post pics of your in dash lcds....
Old Nov 20, 2001 | 04:09 AM
HondaDriver4Life's Avatar
What brand is your LCD? Various companies make brackets and shrouds for their monitors.
Old Nov 20, 2001 | 04:54 AM
sidoe's Avatar
Default Re: Lcd Install?? (HondaDriver4Life)
Here is My System It comes with a stand bracket I don't think this will work for an in dash unit am I right?
Old Nov 20, 2001 | 05:23 AM
mobile authority makes a headrest shroud for your monitor.....as far as brackets go, you'll have to custom make your own to fit your dash. you can use the factory radio brackets as a starting point. the rest depends on how handy you are with ABS plastic, MDF and other common Car Audio customizing materials.
Old Nov 20, 2001 | 05:29 AM
sidoe's Avatar
Oh IC.. where can pu that plastic you mentioned? Who sells it? And about how much...
Old Nov 20, 2001 | 06:22 AM
Select Products specializes in materials for custom installations. They carry pretty much anything you would need. The plastic would be used as your main faceplate - large enough to fill the opening in your dash. You could also use 1/8" or 1/4" thick MDF as the faceplate and paint it to match. Select sells textured paint that simulates the look of plastic. You could then use a colored paint to finish it.
In addition to the faceplate, you would have to make sides that attach to the factory radio brackets. These sides would also be attached to the faceplate. What you should end up with is basically a box but without a top, bottom and back - just the front and sides. Kind of a like a "U" but with right-angle corners. You will also have to cut a hole in the faceplate to accomodate the monitor and/or its shroud.
Hope this helps!
Old Nov 20, 2001 | 06:23 AM
forgot to include the link....here it is:
http://www.selectproducts.com/
Old Nov 20, 2001 | 08:10 AM
sidoe's Avatar
Oh ok thanks for that link.. I know i'm becoming a pain in the *** but you seem to be on point with all the how to's.. I'm wondering now what I should use to bond all this together?
Old Nov 20, 2001 | 09:07 AM
What kind of woodworking tools do you have (i.e table saw, miter saw, clamps, air compressor and brad-nailer gun)? The best way for me to explain the process is to draw up a diagram. I'll try to post or email one as soon as I can.
Old Nov 20, 2001 | 10:33 AM
sidoe's Avatar
Well basically all the stuff you have mentioned I either have or can get through my uncle, if you can do a diagram that would be great you can definitely email it to me ... sidoe@netzero.net Thx alot man...
[Modified by sidoe, 2:37 PM 11/20/2001]
[Modified by sidoe, 2:38 PM 11/20/2001]
justinsouza
Acura TL, RL & ZDX
Apr 15, 2006 07:46 AM
Jos3ph
Feb 12, 2006 02:04 AM
mritch02
Audio / Security / Video
Aug 30, 2004 07:04 PM
sleeperHatch
May 5, 2004 10:48 PM
davem
Aug 20, 2003 03:46 PM
