launching help
Old Jul 14, 2007 | 01:06 PM
95f22a1's Avatar
Default launching help
i have an 89 crx si with a sohc zc with a fully built bottom end. i can't catch traction at launch and i'm launching at 1500 rpm and i still can't catch traction. any thing that i can do to make my front tires stick? or what would you guys suggest me to do?
Old Jul 14, 2007 | 01:18 PM
gsrious's Avatar
use of drag slicks
Old Jul 14, 2007 | 01:26 PM
95f22a1's Avatar
my car sits too low for drag slicks!! what about cheater slicks?
i've been told to not dump the clutch at the line would this be of any help. i figure if i don't dump the clutch then my r/t will be slow!
Old Jul 14, 2007 | 02:36 PM
turboZChatch's Avatar
Default Re: (95f22a1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95f22a1 &raquo;</TD></TR><TR><TD CLASS="quote">my car sits too low for drag slicks!! what about cheater slicks?
i've been told to not dump the clutch at the line would this be of any help. i figure if i don't dump the clutch then my r/t will be slow!</TD></TR></TABLE>
Raise the car up and put some slicks on it
Old Jul 14, 2007 | 03:43 PM
gsrious's Avatar
Default Re: (turboZChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch &raquo;</TD></TR><TR><TD CLASS="quote">Raise the car up and put some slicks on it</TD></TR></TABLE>
or you can use drag radials
Old Jul 14, 2007 | 06:19 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (gsrious)
if your car is dumped, your options are limited. you can try a diff, but with it low, your tire selection is very small.
Old Jul 15, 2007 | 09:47 AM
sircrxracer's Avatar
If the car is dumped then you have very bad contact patch raise the car up and use drag radials. Rob
Old Jul 15, 2007 | 10:38 AM
needmypass's Avatar
do you practice bracket racing or something?? because reaction time has nothing to do with overall time in like a street tune night at a track.
Old Jul 16, 2007 | 02:03 AM
civic_jdm16's Avatar
Default Re: launching help (95f22a1)
MMM.. Could drop. down to about 25 psi. on the tires.. But you porb. already tried that... Trying to hook up in a crx isn't an easy task...
Single cams are a b*tch to hook up with because of the power to wieght ratio.. But then again this is and issue with all hondas...
you have a motor that has almost matched torque with horse power....
your best bet for hooking would prob. be to get a set of G sport traction bars also get a set of slicks get a luanch conrtol setup and launch lower and ride out the clutch a little more
Old Jul 16, 2007 | 03:47 AM
Jay_Sensing's Avatar
I can't disagree more with that.
The only reason he is having issues is because the car is dumped with hideous camber AND on street tires at the drag strip.
We had a 2000 lb crx with a B20vtec and nitrous spraying out of the hole on 20 inch slicks. It would consistently pull mid 1.60's. The only thing wrong with his car is height and tire selection. Sure a traction bar may held once you get everything else worked out but if you are spinning launching at 1500 rpm's with a single, there is a LOT more wrong with the car than a traction bar.
Modified by Jay_Sensing at 10:36 AM 7/16/2007
Old Jul 16, 2007 | 04:30 AM
Default Re: (Jay_Sensing)
Take a little more time to read buddy!!
The only thing I didn't mention that would help him out, is to raise his car....
Read Again
Oh yea if your going to spray a car traction is less of an issue do to the fact once you do hook up and spray your making up for lost time........
Ha Ha Ha and did you say you had a 200lb. Crx ha Bull Spit!!!!
Let me guess you Had the all new Carbon Fiber Engine Block that hasn't even been released in japan yet.....
With the Tissue paper seats, and a big hard d*ldo for a short shifter!!!
Ha Ha your a funny funny guy!!!
Ha Ha if you ever could get a crx to be close to 200lb. driving down the road call me I will pay top dollar for it!!! HA HA
Old Jul 16, 2007 | 05:51 AM
It would be called a typo master of the obvious.
2000 lb car.
As for the rest of your reply, good job. I am glad I didn't finish reading it so you didn't steal too much of my life
Modified by Jay_Sensing at 10:35 AM 7/16/2007
Old Jul 16, 2007 | 06:13 AM
Keep it up King D*ck Pie..
Old Jul 16, 2007 | 06:32 AM
95f22a1
you have PM&gt;&gt;&gt;
Old Jul 16, 2007 | 06:38 AM
Default Re: (civic_jdm16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_jdm16 &raquo;</TD></TR><TR><TD CLASS="quote"> Keep it up King D*ck Pie..</TD></TR></TABLE>
I honestly refuse to go into a battle of wits with an unarmed person.
You continue to show your level of intelligence through you replies so I will bow out prior to you bringing me down to your level and then beating me with experience.
Old Jul 16, 2007 | 07:36 AM
Good Job!!!!!!
Because we could go on for days LOL
Old Jul 16, 2007 | 11:03 AM
95f22a1's Avatar
it's like a war in here!!!!
well my cv axles snapped so i will be getting those before traction bars or slicks!!!
Old Jul 16, 2007 | 11:22 AM
Well all and all I think you find my secret to be a great one!!
Old Jul 16, 2007 | 11:26 AM
95f22a1's Avatar
not really because before i go through all that trouble i will just buy some dr's
Old Jul 16, 2007 | 11:28 AM
Sorry to say again but with a low car the axles are probly binding when your at the track raise it up you will save alot of hassle. I love my car slammed but at the track its way up she goes. Rob
Old Jul 17, 2007 | 03:01 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: (sircrxracer)
Just practice your driving and you will be ok. You should not be dumping the clutch, try pre-loading the drivetrain and slip the clutch so you don't bog out. But something is wrong if your spinning at 1500rpm, are you possibly pressing the throttle before fully disengaging the clutch?
Good luck dude, its a struggle, running slicks for the first time this year, ***** tuff
Old Jul 17, 2007 | 03:29 PM
Mr. Badwrench
Default Re: launching help (civic_jdm16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_jdm16 &raquo;</TD></TR><TR><TD CLASS="quote">MMM.. Could drop. down to about 25 psi. on the tires.. But you porb. already tried that... Trying to hook up in a crx isn't an easy task...</TD></TR></TABLE>
wow. edited deleted rant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_jdm16 &raquo;</TD></TR><TR><TD CLASS="quote"> Single cams are a b*tch to hook up with because of the power to wieght ratio.. But then again this is and issue with all hondas...</TD></TR></TABLE>
2nd wow deleted rant again.
jv88_dc2
Mar 5, 2012 03:39 PM
litovi3tboi503
Apr 4, 2007 02:13 PM
the egg
Dec 20, 2003 08:23 AM
JBk24crx
Jun 8, 2003 06:59 AM
NW94RS
Apr 3, 2002 09:35 AM
