Launching an automatic car....
Old Jun 2, 2005 | 11:45 AM
rotflmao's Avatar
Default Launching an automatic car....
If this is in the wrong board, go ahead and move it.
I have heard that to launch an automatic car, you have to stall the torque converter, by pressing the brakes down and then the gas as far as you need. It preloads the transmission and is safer than N-D drops. But I believe I heard that the torque converter will multiply torque and in some cases(traction permitting), you can autlaunch a manual of the same car. Of course, the top end suffers, but I was wondering if the part about multiplying torque is true. Is it?
Old Jun 2, 2005 | 07:48 PM
RacerStev's Avatar
Default Re: Launching an automatic car.... (dxasaurus)
Yes, most converters give you a 2 to one ratio. So 100 ft pounds with a stick
would be 200 with a auto. The hard part with a auto is getting the rpm up high
enough to get into the power range. If you stall at 2500 rpm and your engine
makes power at 5000 rpm, it's a long slow haul to gain that 2500 rpm.
A little shot of juice will do wonders though....
Some cars will leave better if you flash the converter. Punch it from a idle and
the converter will flash to a higher rpm then stalling with the brake.
Steve
Old Jun 3, 2005 | 11:06 AM
rotflmao's Avatar
Default Re: Launching an automatic car.... (RacerStev)
Thanks for the info.
Old Jun 5, 2005 | 10:55 AM
mastarolla's Avatar
its not good to "powerbrake" an automatic tranny. The results of doing this create a lot of heat and can damage the transmission over time because the transmission fluid overheats and loses its protective properties.
Old Jun 5, 2005 | 11:22 AM
nsxmatt's Avatar
Default Re: Launching an automatic car.... (mastarolla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mastarolla &raquo;</TD></TR><TR><TD CLASS="quote">its not good to "powerbrake" an automatic tranny. The results of doing this create a lot of heat and can damage the transmission over time because the transmission fluid overheats and loses its protective properties.</TD></TR></TABLE>
This is very true on a Honda tranny which are very weak even with a stock DX motor pushing it.
Old Jun 6, 2005 | 11:18 AM
rotflmao's Avatar
Default Re: Launching an automatic car.... (nsxmatt)
I wasn't going to do it with my dx, but thanks.
protopro88
Jan 17, 2013 10:39 AM
pyrojeff
Mar 23, 2004 07:52 PM
trigun7469
25
Jan 15, 2004 10:06 AM
sleeperaccordv6
Jul 29, 2002 09:45 PM
Integra187
Jul 16, 2001 07:09 PM
