launch problems
Old Dec 6, 2004 | 03:00 PM
jdm-crx's Avatar
Default launch problems
i have a 91 crx with a high compression built b16a with a y1 tranny with lsd, well the problem is im lauching at 2,700 and still spinning i have 15 wheels with falken azenis tires, whats the deal with that
Old Dec 6, 2004 | 04:17 PM
Kataku2K3's Avatar
Default Re: launch problems (jdm-crx)
Too much power, launch a little lower or get some slicks and launch a lot higher...
Old Dec 6, 2004 | 04:27 PM
hondaguyef's Avatar
Default Re: launch problems (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote"> get some slicks and launch a lot higher...</TD></TR></TABLE>
If not, Learn how to feather it out of the hole because you are probably just dumping it at 2700. You will be able to launch much higher (even on street tires) if you learn how to get the car out of the hole and moving. Also, Is your car lowered w/o a camber kit?
Phil
Old Dec 6, 2004 | 04:34 PM
jdm-crx's Avatar
Default Re: launch problems (hondaguyef)
its lowered with camber kit on skunk2 drag coilovers with kyb agx shocks
Old Dec 6, 2004 | 08:08 PM
Honda-Tech.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
Feathering is overrated IMO, just losses time. Get better tires or launch just before you bog. Also try loading your clutch useing your e-brake.
slow_SIvic
13
Mar 15, 2007 11:17 PM
4ghatch
Suspension & Brakes
Mar 4, 2007 08:57 AM
Tealeg88
17
Dec 28, 2005 04:27 AM
saigon1965
12
Mar 26, 2005 08:04 PM
MooreBoost
Jul 14, 2004 12:51 PM
