June fs sticky
#51
Sidewinder Turbo Manifold with mulitple options on it for a b-series motor
description
price 450 OBO plus shipping and paypal
Sidewinder Turbo Manifold no cracks great construction heavy duty gauge
for a honda-acura b-series motor.
has a high temp coating
will fit t3 and t4 turbines
will fit tial 38mm wastegate or I forgot the size but the gate that fits the square is almost 500 bucks. So converted it for a 38mm tial.
before the heat wrap and tial 38mm wastegate option added
on a 92-95 civic with b-series swap
and how it is now uninstalled after heat wrap.
description
#52
Selling GSR Fully Built Bottom End
Golden Eagle Sleeves
81.5mm Wiseco pistons
Eagles Rods (3/8" bolts)
Honda OEM Bearings
GSR crank (polished and radius oil holes)
GE Oil Squirter Plugs
Oil pan, tapped or no that's not tapped, I have both.
Endyn modded Type R oil pump
Type R water pump
Machine work was done by Pro Machine here in utah. Motor made 850+hp, ran a total of 6 times (3 full passes) and about 10 dyno pulls. Fastest time was 10.00@148mph. Motor runs awesome! Block did have a small crack in the front from the headstuds pulling the block apart. It's been fixed and haven't had any problems what so ever!
Asking $2250 obo + shipping
Hasport mounts for EG or DC2 B series. Used 6 times and 10 dyno pulls. Look brand new, have the rubber race inserts.
$280 Shipped
Honda OEM Bearings
Type R water pump
$280 Shipped
#54
Re: (BLKTeg94)
Honda OEM Bearings
Type R water pump
will you ship to canada? email me at Brown_age@hotmail.com
Honda OEM Bearings
Type R water pump
#57
Re: 97 Civic Coupe SFWD turn key car (wright54)
I will have pictures up in a bit. I am selling a Good Good condition PRECISION 750HP intercooler with brackets that will fit any integra and EK. I am asking 350 shipped and i am pretty firm on the price. Only reason i am selling it is so i can make a custom one. Please message me with any questions. I will have pictures up later today.
Also have a custom catch can that fits where the battery sits. Its made out of stainless steel and has 4 -10 bungs welded on and 3 1'' breather's on top. It is also baffled inside. i am asking 125 shipped for it.
Modified by 0554 at 10:31 AM 6/15/2008
#58
Made by Garage 808 for my drag car. The mani is T3/38mm flanged and the DP is a 5 bolt 3" flaring to 4" with flex pipe thay are also now heat wrapped
650 obo +shippinig shoot me some offers
mani
DP
mani
DP
#59
Re: (Garage 808 Hatch)
#60
Re: June fs sticky (boostedcivicsir)
06 Rs-x type-s 6-Speed Tranny complete tranny. Does have vin plate and is legit will come with Bill of sale mileage not sure of and does need ring gear i also have the shift cables for the tranny which will be inclueded asking 300Obo Pm me for contact info or email me at boostedtacoracing@yahoo.com[img]http...4/IMG_0831.jpg[/img]
#61
AFI T4 Topmount manifold & 4"Down pipe & Dumptube $1200
Tial 44mm WG $275
3" aluminum intercooler piping, bead rolled, couplers, t-bolt clamps, $200
Tial 50mm red BOV $175
Full Race back door intercooler 20x10x3 in. core supports up to 720whp...$400
All parts have less than 1k miles on it, buy everything listed above for $2000 obo
GSR complete long block:
AEBS 84mm sleeve, 10:1 Endyn Rollerwave pistons, Manley turbotuff rods, OEM water pump, OEM oil pump, OEM bearings, Cometic headgasket, GSR head with Supertech oversized valves, multi-angle valve job, Crower springs & retainers, GSR cams $2500
Brand new Competition Clutch Twin disc clutch for B-series $1000
Polished B16 hydro transmisson with Quaife $1250
M&W Pro 10 Ignition box, harness, Crane coil, OBD1 GSR Distributor ( no coil, no ICM) MSD cap, wire from coil to cap $550
Precision 1600cc Injectors $250
Complete Fuel Setup: Bosh fuel pump, Aeromotive filter, -10 from tank to pump, -8 from pump to STR fuel rail, Aeromotive FPR, -6 return line, all braided line and Earls fitting $600
GSR JG intake manifold ported out for 72mm TB & hondata gasket $280
72mm RPM Service TB $250
Scatter Shield $100
Fluidyne Radiator & Fal fan $250
Turbo XS Quad stage Boost controller $250
Innovative Wide band and display $200
13" Lensos & M/T 24.5x9x13 slicks $450
Modified by MaxBoostC1 at 8:34 PM 6/17/2008
#63
Re: (buck02)
4" Aluminum Exhaust - Made in House by TEMPEST RACING.
V-band connection at the downpipe side. Goes under gas-tank.
Looking to get $400 Dollars for it, would prefer local pickup.
#64
Re: (Jeff @ Tempest)
welded up b16 trans with quaife and fifth gear handcuff in case $1000
liberty faced b16 gear set with spool in case. $1000
jg dual injector manifold with fuel rails(gsr) $300
jg manifold with 22.5 angle before plenum 75mm throttle body flange. (gsr) $275
vemon b16 manifold $150
jg victor x manifold $225
ferrear roller cam set up. brand new stock size valve, springs for cams, single roller kit (newer style) 10007 cams. Cams made 730whp at 30ish psi. Best offer.
Benson sleeved block. Best offer.
motec m400 harness for b series, Cannon plug for firewall. All Dr-25 $400
ken custom chassis brake booster delete kit (new) $95
Kens custome chassis parachute kit (new) $60
fast brakes drag brake set-up $300
Weldon 2345 fuel pump. $700
Full Race top mount $1000
Gt42R $1300 PM for Details
crower rods (one has spun bearing) $200
manley turbo tuff rods (new rod bolts) $350
Eg shell (black) with 8.50 and slower cage certified. parachure mount and window net $1500
Hot Pink parachute (new) $200
M&W pro 14 cdi box $700
Rota 13X8 wheels with slicks (Unkown condition)$200
No pics at this time.
#66
Re: (integlspwr2k)
Brand new in box G-FORCE *black* window net, plus install kit $45 SHIPPED for everything
also...
Brand new in box MAZWORX parachute release kit w/ handle, etc. They sell this for $80+ shipping and are currently backordered. I will sell for $75 SHIPPED:
Paypal preferred, thanks!
- Louis
also...
- Louis
#67
Re: (HybridKOOP)
I have a B series (LS) hydro tranny with a Circuit Worx Pro Drive spool that I have no use for. I'd like to either sell the tranny whole, or will part out the spool if the price is right. I'll also accept trades for a clean GSR tranny, a Quaife LSD, 6 pt. cage, or possibly other stuff you might have. $400
#68
Re: (guymosiris)
Brand New Tilton Cermaic Clutch kit for H22 $1140 shipped
Brand NEW h22 trans From HONDA with Brand new Quaife LSD $1500 obo
Brand New Quaife LSD for H22$895
#71
Im gonna sell my race car as a shell...The paint is still good in it may need a good wet sand and buff, but over straight with no dents...Car has a clean title...Here are some details on it and what it will come with...
94 Acura Integra LS
Black paint w/ orange pearl and orange flames with pinstriping...
CFhood, CF sunroof plug, CF trunk
10 Chromoly roll cage (certified), Strout window net, JAZ racing seat, Gforce 5pt harness
Custom BBS drag wheels and skinnies, M&H 26x8.5x13 slicks...Only two sets ever made...
Tokico Illumna coilovers with skunk2 drag launch springs in the rear, SPC rear lower control arms, SPC front upper adj. arms, DC Sports rear lower tie bar,Slotted rotors on all four corners, SS brake lines
6+ gal fuel cell, STR rear diffuser, Z10 traction bars, skunk2 short shifter, RPM and MPH autometer gauges....
Car weighed around 2100 lbs with turbo B series motor...1.6 60's all day
Price: $4800 OBO...
94 Acura Integra LS
Price: $4800 OBO...
#72
Re: 97 Civic Coupe SFWD turn key car (anothaRRR)
For Sale brand new ERE Dog Box for B series with all GSR gear ratio's / w a 4.5 final drive,was made for SFWD specs,it will include a brand new Quaife LSD.
Asking price $4799 OBO
For more details please "pm" me or click on link. http://www.ericksracing.com/id72.html
Sold Sold!!!!!!!!!!!!!!
Modified by Javier at 5:19 PM 6/25/2008
#74
Re: (tagperformance)
we have a set of used Crower LS turbo cams for sell they are in great shape. asking $250.00 o.b.o. plus shipping and paypal fee. i will try and put up some pics tomorrow.
Modified by 1qkfodo at 1:31 PM 6/22/2008
#75
** RESTRICTED **
FS:
-RC 750 Injectors w/ clips.
Pretty much brand new injectors. Only ran on the dyno when my motor gave way so Im parting the project. [B]SOLDB]
-Chipped P28 and OBD2-OBD1 Conversion Harness. $195 shipped
-EK Carbon Fiber Hood......(Has some oxidization but you can reclear it with a can of duplicolor clear and wet sand it or just get it painted. Its a cheap way to loose weight. ) $SOLD
Modified by PharcydeH23 at 7:35 PM 6/18/2008
Modified by PharcydeH23 at 10:44 AM 6/20/2008
Modified by PharcydeH23 at 3:51 PM 6/20/2008
