july fs thread
Old Jul 3, 2011 | 03:35 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default july fs thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Jul 3, 2011 | 04:02 PM
PRO1's Avatar
Default Re: july fs thread
Circuit werx Ring gear and Pinion
Bseries 4.4 Ring Gear
make offer
704 604 3526
[IMG][/IMG]
[IMG][/IMG]
Old Jul 3, 2011 | 04:26 PM
Jaker's Avatar
FS: Rob Moore Performance Nitro Driveline front knuckles for Civic EG/EK, Integra DC.
Knuckles sold, Knuckles sold, Knuckles sold, Knuckles sold, Knuckles sold, Knuckles sold.
Brakes still available, Brakes still available, Brakes still available, Brakes still available.
These were bought slightly used from DaveF about 3 years ago. They were installed on my 1991 Honda Civic Wagon RWD autocross car. I ran about 8 events on them and drove about 2,000 miles on the street with them. I'm now parting out the car.
The bearings are very low miles. I think Dave put about 500 miles on them tops before I bought them. So the bearings have a max of 2,500 miles. The lower balljoints are the same (about 2,500 miles). The hubs are Integra and compatible with Civic/Integra regular outer joints. ARP extended studs. Black powdercoat with a couple chips here and there, and a bit of paint touch up on the backs.
They are also available with the brakes and rotos shown in the picture. The calipers are Wilwood Dynapro6 6 piston calipers with 2 sets of brake pads: Polymatrix A pads and BP20 pads. Both sets have a max of about 1,000 miles each on them. The rotors are 2 piece with aluminum hats and 10.75" cross drilled rotors (they came that way from Wilwood).
I'll incude the front stainless braided brake hoses set up to connect to Honda OEM chassis lines.
The knuckles on their own are $500 plus shipping. They're about 6 lbs per side lighter than OEM. Complete with the brake setup is $900 plus shipping. Calipers and rotors are also 8-10 lbs lighter per side than OEM. Shipping is from Blaine, Wa 98230 or if you're in Canada, it's from Vancouver, BC V4A 8E6.
Here's a pic of when they were fresh from the powdercoater. Now they've got a bit of dirt/brake dust on them, and the rotors have some minor wear.
Old Jul 3, 2011 | 04:45 PM
Slappy's Avatar
Price
$1200 or best "reasonable offer"
Contact information
armachac@gmail.com
New
Product description
I'm going a different route and letting this go after holding onto it for 5 years.
This is new
All Pics takin by Booja
I will not trade.
Shipping can be arranged at an additional cost
Paypal: armachac@gmail.com
Turbo flange is a T4
Old Jul 3, 2011 | 05:21 PM
J. Mills's Avatar
SOLD
NEW in the box..
$420 plus shipping cost..
Wiseco Pistons
For B Series
Part Number : K542M81
Stock Bore (81mm.. 3.189")
(B18a/B18b) 9.3 - 9.8 compression
(B18c) 9.7 - 10.2 compression
(B18a/B18b with vtec head) 9.8 - 10.2 compression
(B17) 9.1 - 9.4 compression
(B16) 8.8 - 9.0 compression
Old Jul 3, 2011 | 06:53 PM
JamaicanDave's Avatar
innovate EK race mounts(i do have driver side not pictured) 100
3pc exospeed **CLOSED FRONT** -850 firm
cms racing spindle mount 15x4 make offer
franks fiberglass hot rod style 1pc front end-- make offer
P29 pistons and rings 100
**items for sale do not include shipping or pay pal fees**
Old Jul 3, 2011 | 07:57 PM
JJsMotorsports's Avatar
I'm cleaning shop, I got my old IC water to air built solid and has held 55psi no problem, temps stay down(bell core) as long as you don't put too much boost like 60psi asking 1000.00 I've run 9.0 twice with this little guy and 170mph! So it works!
Next some wiseco all motor pistons(13:1-14:3) 85mm 250.00. Next some pro3 cams from skunk2 in great condition they have about 10miles....asking 350.00....I also have 880cc Precision low Imp injectors,almost new, got dyno time on gas 93. asking 240.00 still in box.
If you need more info please text me or pm me 210-214-8542
Shipping and fees extra.
Cams Sold Thank you H-T!
Old Jul 3, 2011 | 08:28 PM
HickamHatch's Avatar
J32a2 Pauter Rods. $800
02 TL Type S automatic longblock with wire harness $750
04 TL Type S manual trans with LSD with new slave cylinder $1500
Upper Intake manifold and throttle body off 03 tl type s $200
Hasport EGJ2 mounts with 90a urethane $450
J32 Swap Hasport Axles. $275
J32 V6 Automatic Halfshaft (This IS the one you need for swapped cars) SOLD
K series Hybrid Racing shifter... SOLD
(2) Rota 15x8 with +26 offset. Very hard to find rim and hardly ever in stock. Can run these without spacers with a 235/60-15. Satin black and 4x100. I'll pull the tires off as soon as they are sold $250
5 LUG 5x114.3 type R 36mm spline. Front only $300
EG/DC Blox orange anodized rear LCA $75
Skunk 2 EG/DC front camber kit $100
92-95 EG Exospeed front. $650
K sport EG/DC coilovers. One of the fronts needs rebuilt. $600
Tokico Blue with H&R springs Low miles, still on car. $500
Selling silver carbon fiber hatch and duckbill from EG also including a silver anodized diffuser. Asking $600 for all
Haltech platinum 2000 w/ flying lead harness brand new in box
Everything untouched and ready for new home $1800
AEM K series fuel rail. $125
Selling my k-tuned kit. Only has 100 miles on it. Has -16an hose ends welded to it. There is a -8an line from waterneck to housing. water temp sensor for gauge cluster and fan switch are both included and installed into the housing.
$250 OBO
K20a2 harness. Was running this on my turbo setup and should be plug and play for your setup. Has the obd1 injector clips wired in. The thermostat and fan switch are wired in to run to the K-tuned thermostat housing. GM 3 bar map sensor wired in and included (no more stock sensor). Honda resistor box wired in and included. The Knock sensor and alternator wiring is in this harness so you dont need a jumper harness. All you will need to do with the jumper harness is positive and negative for alternator and starter. $300 OBO
Custom K series catch can
Orange valve cover with -10an bungs
Comes with (4) -10an lines to valve cover
$400
HKS EVC 5 boost controller/gauge
Digital read out, had it in my car for a while and it works great but using boost by gear so i dont need it anymore
Needs the power plug, Should be no more than $15 from HKS dealer
$350 OBO
Blitz FATT DC turbo timer
works great
$75
DC sports rear lower tie bar
fits EG/DC
$75 shipped
Neuspeed EG/DC strut bar. Should kit EK also
$100
3" Stainless braided FLEX PIPE
Brand new
$50
Old Jul 4, 2011 | 05:00 AM
yzracer323's Avatar
All prices are best offer, but keep it reasonable please. Prices do not include shipping or Paypal fees unless noted.
Skunk 2 Front camber kit, 96-00 civic(1 kit for sale) $69
3" Stainless steel Exhaust off my EK,V-band, Black Vibrant muffler $300 picked up
Mishimoto radiator w/ -6an bung and slim fan $149
NEW 54" Stainless clutch lines with SS fittings for MC/slave cylinder(I have a bunch of these), fits 92-00 civics and 90-01 integras $59/ea, shipped/Paypal fees included
Competition Clutch, Stage 4, 6 Puck sprung, B-series hydro $225
Brand NEW aeroquip fittings for brake tuck, includes all fitting(I have 2 kits to get rid of, 1 black, 1 silver) $129 shipped/Paypal fees included
Disassembled GSR head w/camshafts, P72-1 stamped $299 OBO
NEW Aeroquip AN fittings and hose, I have a TON of this stuff. Let me know what you need.
2 fuel lines for OEM filter to rail, $59/ea, shipped.. one black, one SS
PUSH-LOCK Vacuum Fittings and 1/4" tubing, NEW. I have a ton of these also. Let me know what you need, I have about 30 of the 90*, straight, tee's, and about 50ft of tubing. Pic show a single wg setup, setup for solenoid, you get the idea
Old Jul 4, 2011 | 05:15 AM
SynTeg's Avatar
Used B18A/B Eagle H-Beam Rods 3/8" bolts
Good Condition
$180 shipped add 3% paypal fees
FJO Injector Driver for Peak and Hold/Low Impedance Injectors
$150 Shipped add 3% for paypal fees
HKS SSQV Blow off valve
$75 shipped add 3% paypal fees
Old Jul 4, 2011 | 07:35 AM
Themouse's Avatar
Fs:
Wiseco Piston Rings 84mm Brand New-$120obo
Old Jul 4, 2011 | 08:12 AM
kte324's Avatar
**Click on pictures to expand**
Setup made 586whp @ 24psi on C16. Engine runs great, does not smoke, knock, or have any issues. Compression test showed 200psi across all four cylinders. Transmission shifts perfect with no grinds. I have videos of the car running along with compression test hours before the engine was pulled for serious buyers. Pictures of the build can be found here: http://s413.photobucket.com/albums/p...ne%20%20Build/
Prices do not include shipping. Pm me for more pictures, prices, or information.
-B16A2 Benson Sleeved Block $2750obo
-9.1:1 CP Pistons
-Pauter Rods
-Acl Race Bearings
-Moroso Oil Pan
-GE Oil Squirter Plugs
-Block Machining & Assembly done by Laskey Racing
-Arp Head Studs $90obo
-Gates Blue Racing Timing Belt $65obo
-Msd Sci Ignition Box $125obo
-NGK B16 Spark Plug Wires $45obo
Old Jul 4, 2011 | 08:37 AM
choadsi's Avatar
Means of contact: pm or text 7579278784
Price: $2500
Description: 98 Ek Coupe fully caged and NHRA cert'ed rolling shell for true street with a title in hand
trying not to part either unless the shell sells for cheaper then posted
update for those planning on streetin this shell it has no heat, you can mod a heat setup in there easy, just not the factory one
also the hood could use a reclear
-stock fuel cell
-AEM fuel rail
-MSD blaster ss
-Gator 1000hp axles w/stock spindles/hubs
-sparco 333 wheel
-dc sport shift ****
-del sol seats
-crow 5 point racing harness
-rear bump cut for air flow
-si tail lights
-99-00 si front end
-comes with steelies
will try to get better pictures when i can this is all i got
Pictures:
hood is just popped
boo boo
Means of contact: PM or text cell 757-927-8784
Price: $2500
Motor:
B16A2 84mm bore Dart mid sleeved
8:5:1 wiseco pistons
Eagle Rods
acl bearings
Head:
Type r cams, valves,retainers everything a R head comes with plus
Rev Springs
Motor made 590 on a 35R at 28psi and in the drag shell, i am selling, ran a best 10.5
Pictures: only pic i got not selling anything but the motor in the pic so don't ask about the top mount or the 35R or anything else
the drag shell is for sale though :D
Last edited by boostedcivicsir; Jul 4, 2011 at 02:52 PM. Reason: 1 post only please
Old Jul 4, 2011 | 08:56 AM
85mmek9's Avatar
Up for sale is Shuriken sk-bt35 battery and works flawlessly!! I used it for about a year in the race car but im relocating my battery so I need to sell this one. This battey has been sitting on my bench for about 6 months and the meter still reads 12.8v. This battery sells for around $110-$120
Amp Hours: 35
Cranking Amps: 950
Weight: 25 lbs.
Dimensions: 5-1/4"D x 7-3/4"W x 6-3/4"H
$75
Old Jul 4, 2011 | 09:06 AM
BrowNKiD's Avatar
BNIB Tial Wastegate 60mm $400
Old Jul 4, 2011 | 11:00 AM
project-boosteD's Avatar
Barry Grant 400 external fuel pump, don't know to much about this unit... your research on this, is as good as mine.
$250
shipping and paypal not included, but willing to meet in the gwinnett area. i'll also be in nashville for import alliance and can meet you there.
Old Jul 4, 2011 | 11:27 AM
jdm inc's Avatar
I have some b-series turbo parts im selling.
please text/call me at 620-222-1513
parts are OBO! these do not include shipping or pp fees
B series log manifold no cracks no flaws etc. Only used for start up. 150 OBO
Intercooler. Id have to measure the size. not for sure. 140 OBO.
dumptube $50obo
downpipe 4 bolt. has two o2 bungs. 150 obo.
4"sls dp 400 shipped.
random pipes make offer
Old Jul 4, 2011 | 12:18 PM
MrParks's Avatar
free shipping on most items in the us.
intl orders will be additional charges.
paypal fees apply
first come first serve basis.
info@fcsfab.com paypal addy.
if you have immediate questions of would like to purchase the item please email me at info@fcsfab.com thanks
autometer carbon tach. used but great condition. comes with shift light, mounting hardware ect. pleaty of wiring on it still. can convert back to 6-8 cyl as well.
120.00
aluminum v band kits. 4 left. sizes are : 1x 2.5" 2x 3" and 1x 4" 30ea 4" 45.00
FCS battery box, display item semi polished unit. used for display. mint cond. comes with all the straps and hardware for easy installation. all associations approved, deemed legal in all motorsports.
155.00
burns 4" race muffler. used mint cond. 175 obo
here is a link to the muffler for dia and dem.
http://www.burnsstainless.com/sm-400-550-12.aspx
FCS 5 gal fuel cell. -10 feed, -6 return. no sender unit for this item. used for test fitment in a da. race proven by many top teams in the country and worldwide.
fits 88-00 civic/crx all models, 89-01 integras all models,
mint condition very clean. can take new pics. comes with all the hardware, straps ect.
350.00
k series cast turbo manifold w/ turbosmart 38mm ultra gate. manifold has never been used. new. wastegate is used. 300 for both or can part out 160 each.
new AEM regulator blk only took out of the box for pics. it is complete with all the hardware fittings and decal.
125.00
momo small steering wheel with ef/crx hub. clean. 100.00
carbon monster autometer tach mint cond. 150.00 comes with tach mount and shift light.
2 mechanical oil pressure gages, 20 each
1 water temp gage mechanical 30.00 is great condition.
gage pod for ef crx civic models. 10bux
apex vafc ol sckool but still works! complete harness as well. 40bux.
3 gallon box tank. sumped. has foam baffling. used in good condition. -8 fittings all around. 100.00
msd in line pump 255gph 125 max psi. used in good condition. 60.00
aero filter sold
email: info@fcsfab.com for quick response. 24/7
paypal fees apply
Old Jul 4, 2011 | 08:48 PM
b18c1Monster's Avatar
4 inch aluminum exhaust for eg/ek hatch
500 obo plus shipping. Fits good and looks nice
Call or text 203-479-2274
Old Jul 5, 2011 | 04:32 AM
BlueByYou's Avatar
*used garrett 4294 with 128 ex. housing (good condition)-$1000
*used pr3-3 head w/o cams-$300
*10lb nos bottle-$100
*str intake manifold (gsr)-$200
**-does not include shipping or paypal fee!!
Old Jul 5, 2011 | 05:40 AM
tuhboek's Avatar
1. 4 inch down pipe with v-band & O2 bung LIGHTLY USED- $425
2. ID1000cc injectors less than 30 min of running time- $450
3. Universal racing seats small hole on both bottom cushions (as seen in pic) - $145
4. MSD HVC Blaster Coil used/great condition- $85
Prices do not include paypal fees or shipping fees, it is all negotiable though.
More pics upon request
Call/text for fast response: 620 262 7796
Old Jul 5, 2011 | 09:31 AM
TopEndUSA's Avatar
sold
Old Jul 5, 2011 | 02:20 PM
Evo1's Avatar
OG Fabricator
PTE 6765 Turbocharger
Journal Bearing
Ported H cover
t4 1.15 divided housing
Brand new never used
$1000 OBO
Old Jul 5, 2011 | 03:45 PM
EDLOVA23's Avatar
IF INTERESTED CALL 973)390-2982
i have 2 B-series shift linkages 1 with a B16 shifter and another with a GSR shifter $100 each
GSR - victor x edelbrock intake manifold $250 or best offer
Professional Products 68mm throttle body $150
Precision injectors 1200cc - $320 shipped in the U.S
custom catch can sits next to the battery $275
the bracket is welded onto the battery tray
comes with
battery tray w/ bracket welded to it
all 4 lines and fittings minus the 2 fittins on the actual block
aem ecu obd1 1040 box - $850 or best offer
wrinkle blue valve cover $100
aluminum 4" exhaust and muffler $700 or best offer
prefer local pick up from north jersey
ROTA'S CTR REPLICA 16" WITH TIRES $700 OR BEST OFFER
RIMS DONT HAVE NOT ONE SCRATCH OR CURBAGE TIRES ARE IN PERFECT CONDITION
Old Jul 5, 2011 | 06:25 PM
NAH2B's Avatar
800. stock b16 trans excellent condition. buyer is welcome to open it up and look it over before they buy.
140. brand new k tuned fuel pressure regulator w/ liquid filled guage
80. holley fuel pressure regulator (rail mounted)
