ITR track setup
Old May 15, 2003 | 01:41 PM
TypeR1558's Avatar
New User
Default ITR track setup
I plan to do some dragging in my ITR at the track, starting in a few months.
Need some advice on a wheel/tire setup. Right now I am daily driving with falken azenis on the stock 15 inch wheels (5 lug). I would like to have a set of slicks mounted to a set of wheels for the track.
Do bogarts help that much? Which are the best make? How much are they? Will they mount straight up to the car?
As for suspension, i am currently just riding with H&R sports on the stock shocks - just thought I would mention than incase it had an effect on running the bogarts.
If not bogarts, then I am thinking the best thing to do would be to get a set of larger "pretty wheels" for the street (like some 17 inch LE's), and then mount some slicks on my stock rims for the track.
What do you all think? Opinions?
Thanks,
Jon
Old May 15, 2003 | 07:45 PM
MackSpeed-616's Avatar
Default Re: ITR track setup (TypeR1558)
swap to a 4 lug conversion and get some 13" slicks
Old May 16, 2003 | 02:56 AM
TypeR1558's Avatar
New User
Default Re: ITR track setup (BustaNutt-616)
How much does a 4 lug conversion usually cost? downsides to doin it? I guess I wont be able to fit the stock wheels, so what will fit on the 4 lug?
Jon
Old May 16, 2003 | 07:19 AM
Broken Gearbox's Avatar
just wondering what would be the cheapest way to run 13s with a Type R?
Old May 16, 2003 | 09:19 AM
2001TypeR's Avatar
Default Re: ITR track setup (Powered By D15)
I/H/E Tires, like Bfg drag radials/falkens/so3's, all that with a good driver should do it considering you are close to sea level...
Cheapest way? Probably slicks and an intake or something with good driver and high rpm launches..
Old May 16, 2003 | 12:58 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: ITR track setup (2001TypeR)
Well you could try running drag radials and see how you like that. Or you can get another pair of 15" ITR wheels or drag wheels and try some 22x8x15 MT's. Or mount these on your stockers and get some blingin 17's.
Old May 16, 2003 | 01:01 PM
Default Re: ITR track setup (Mr Milano)
how about a cold air intake...jdm itr header...carsound cat....2.5 mandrel-bent piping and some BFG's??...no slicks
Old May 16, 2003 | 01:19 PM
TypeR1558's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Well you could try running drag radials and see how you like that. Or you can get another pair of 15" ITR wheels or drag wheels and try some 22x8x15 MT's. Or mount these on your stockers and get some blingin 17's. </TD></TR></TABLE>
Sounds like the most probable option so far. No matter what the scenario, I'd like to use slicks at the strip, and sticky street tires when daily driving. I dont want to run drag radials. Ill just cruise to the track on the slicks cuz it's gonna be only 15 min away.
How come there aren't any bogarts that will fit 5 lug?
Again, how much does it generally cost to convert to 4 lug?
Would the weight/diameter of a bogart really be worth doing all of this stuff, or would a stock wheel/slick net me almost the same 1/4 time? What kind of a difference in performace are we talking about?
Jon
heyitzspikey
Oct 6, 2015 08:10 AM
jdmmonkey
Northern California (Sales)
Mar 20, 2007 08:30 AM
Nextelbuddy
Jan 27, 2004 09:59 AM
F1Spec
Mar 27, 2003 04:19 PM
Black R
Apr 22, 2002 03:47 PM
