Integra axles?
Old Jan 11, 2005 | 05:39 AM
86si's Avatar
Default Integra axles?
Are 93 axles compatable with 94? I'm asking because I can buy Prodrive axles and hubs from someone local and they are for a 94 hydro trans.
Old Jan 11, 2005 | 04:18 PM
DEVIOUS_EG*'s Avatar
Default Re: Integra axles? (86si)
you would have to use the 93 interm. shafts if you use them
Old Jan 12, 2005 | 01:13 AM
Full-Race Geoff's Avatar
convert to a hydro trans and who cares
if its possible to do in your chassis (hasport probably can help you) there are a lot of strength gains to be had. something worth considering if you are at the point of needing stronger axles
Old Jan 12, 2005 | 01:35 AM
hondaguyef's Avatar
Default Re: Integra axles? (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">Are 93 axles compatable with 94? I'm asking because I can buy Prodrive axles and hubs from someone local and they are for a 94 hydro trans.</TD></TR></TABLE>
Use the 94up I-shaft and you'll be fine.
Phil
Old Jan 12, 2005 | 08:04 AM
86si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">convert to a hydro trans and who cares
if its possible to do in your chassis (hasport probably can help you) there are a lot of strength gains to be had. something worth considering if you are at the point of needing stronger axles</TD></TR></TABLE>
Hasport does not make a conversion for the 84-87.
As for a Hydro trans. being stronger than a cable that's BS. I have worked for Honda for 8 years and rebuilt countless M T's, they are of the same materials internally. Syncro design has changed over the years but thats about it.
Old Jan 12, 2005 | 10:40 AM
you are saying that the shaft size is the same from cable to hydro? What about input shaft? ... they are much larger on the hydro trans...
Old Jan 12, 2005 | 10:58 AM
86si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">you are saying that the shaft size is the same from cable to hydro? What about input shaft? ... they are much larger on the hydro trans...</TD></TR></TABLE>
90-91 input shafts are smaller yes, i am running a 92 YS1 which has the larger spline.
Old Jan 12, 2005 | 11:04 AM
Suprdave's Avatar
Just change the Midshaft and you will be fine.
92-93 and 94+ are same length.
Old Jan 12, 2005 | 01:01 PM
4piston's Avatar
Default Re: Integra axles? (Suprdave)
I have a 93 shaft if you need one
Silspeg6
May 30, 2007 10:34 AM
CWESTINAP1
Jan 20, 2006 09:34 PM
JDM_Ej
22
Jul 26, 2005 07:41 AM
foursquarepunk04
Feb 3, 2004 08:42 PM
SignfcntOthr
Oct 25, 2003 06:21 AM
