Improve traction
Hi guys, to impove traction on my civic ef turbo which is the better to choose from a 4.05 final drive or just put a gsr second gear.
I have a jdm itr 96 spec tranny with the 4.4 fd.I use it for the strip and already use mt drag slicks 26/8.5/15 and spins all second gear
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">
lower the tire pressure ! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melovesboost »</TD></TR><TR><TD CLASS="quote">What are the track temps like? Track doing good Prep? Getting a good Burnout? How much power are you making? Suspension setup? tire pressure? </TD></TR></TABLE>
I am making 2nd gear burnout,i have about 500whp .The suspension is koni yellows with skunk 2 drag launch,traction bars and the tyre pressure is 7 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97R »</TD></TR><TR><TD CLASS="quote">It has a high and low option</TD></TR></TABLE>
Is it switchable on the fly? If you only have 500WHP and your lighting up those 26"...sounds like you need a new set of slicks.
superhatchbackbros
10
May 30, 2006 10:19 PM
