How much power can stock B18B sleeves handle, crack one last night @ 20 psi
Old 09-14-2003, 08:30 PM
turbolsintegra26's Avatar
Default How much power can stock B18B sleeves handle, crack one last night @ 20 psi
I Cracked a sleeve last night on 20 psi . It was my first time to crank it up that high. I run 14-15 psi daily and it loves it. I have JE pistons 9.2:1 comp 20 overbore. Eagle rods w/ arp rod bolts, ARP head studs. all assembled and machined by a excellent machine shop I trust. The block guard was installed by an idiot. so that could be it. Ive been told that stock sleeves can hold 20 psi every now and then. I using the S-afc hack with 450 cc injectors, and I have plenty of fuel, and its tuned fairly well. I guess it's time to go with stronger sleeves and suggetions and any ideas of prices, like darton sleeves with installation? I've heard of some of the sleeves having cylinder cooling problems any suggestions?
Thanks Justin
Old 09-14-2003, 08:32 PM
tony1's Avatar
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (Turbointegra22)
20 psi and afc hack, there's your problem! You had way too much timing for 20psi! Get a hondata, sleeve your block, and don't go through this again...
Old 09-14-2003, 08:42 PM
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (tony1)
Are you saying that detonation caused it? I also had just installed a water/methonal injection kit. Could that have been it? I had my timing retarded. Thanks for the help Justin
Old 09-14-2003, 10:03 PM
wHOAlly's Avatar
afc cannot control ignition timing, so reguardless if your running no boost, or 20 psi, your ignition maps are the same...
Old 09-15-2003, 11:07 AM
95c1v1cs1's Avatar
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (Sp00n'd Supra)
Stock Sleeves,V-AFC Hack and 20psi= Please tell me you had a Ignition Timing Retard device? If not, Timing Owned you.
Old 09-15-2003, 06:17 PM
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (95c1v1cs1)
Thanks for all your replys. First off I had no BTM, but my timing was retarded 12 deg. 16 when I turned up the boost. Second it was detonation, my new JE pistons had small signs of being torched on the edges of the valve reliefs. I just pushed way too much. I'm now wondering if I can even still use the block, and just have it resleeved with a darton set?
Old 09-15-2003, 06:30 PM
TurboJesse
Guest
Posts: n/a
450's @ 20 psi, talk about injector duty cycle Welcome to Honda-tech, hopefully you will learn alot in your stay.
Old 11-18-2004, 04:51 AM
Tex Blackwell's Avatar
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (Mpir3)
i should be dynoing a stock block b16 w/ 9:1 pistons, rods, hondata 750 cc's and probably 20lbs, depends on how things go, and 116 octane sunoco
Old 11-18-2004, 05:36 AM
FIxALPHA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">20 psi and afc hack, there's your problem! You had way too much timing for 20psi! Get a hondata, sleeve your block, and don't go through this again...</TD></TR></TABLE>
A friend of mine has a similar setup as you, but instead of the afc hack, he used hondata and 1000cc injectors. 24psi and 475whp.
His Setup:
LS/VTEC, CP Pistons (9:1) and 20 over, Manley Rods, Block Guard and he assembled it himself.
Old 11-18-2004, 06:19 AM
99lspwr's Avatar
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (FIxALPHA)
Was this on pump gas as well??????
Old 11-27-2004, 09:37 AM
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (99lspwr)
not sure i wasnt using pump gas on mine
Old 11-27-2004, 11:31 AM
Aggressive Racing's Avatar
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (mp3albums2k2)
I would also like to add that going 20 over on stock sleeves then boosting 20 psi didnt help either,if your gonna run anything over 18 psi on stock sleeves try to keep it stock bore!
Old 11-27-2004, 03:23 PM
Chrome Pipes's Avatar
Default Re: How much power can stock B18B sleeves handle, crack one last night @ 20 psi (aggressivemotorspor
What kind of gas where you using? I've been running almost 360 whp on C16 with no apparent problems. Stock pistons/rods, stock sleeves LS/VTEC with a gangsta InlinePro style VAFC/FMU/RC 440/Holly 255 intank mickey mouse fuel setup. Timing is at 14 at idle with no btm.
Old 11-27-2004, 08:48 PM
fullracegsr's Avatar
Congrat's Jay on your new personal best...
Paul
Old 11-28-2004, 08:25 AM
gotta love that c16
Old 11-28-2004, 10:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullracegsr &raquo;</TD></TR><TR><TD CLASS="quote">Congrat's Jay on your new personal best...
Paul</TD></TR></TABLE>
Hey thanks.
C16 owns! It also owned my wideband!
Old 11-28-2004, 07:20 PM
E Town DSM's Avatar
Whats wrong with pump?? C16 is nice.
Old 12-10-2004, 03:46 PM
c16 is great,
Old 12-10-2004, 04:41 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mp3albums2k2 &raquo;</TD></TR><TR><TD CLASS="quote">c16 is great,</TD></TR></TABLE>
wtf does c16 have to contribute? Lets get back on topic here. Hes not asking about what fuel you guys run.... Common.
For your sleeves, i have 'heard' more problems with cooling on guys running blockguards vs. sleeving the block.
Perosnally if i ever had a block sleeved it would get shipped off to GE.
Old 12-10-2004, 04:51 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
Perosnally if i ever had a block sleeved it would get shipped off to GE.</TD></TR></TABLE>
lets talk about what you heard ??? LOL
why GE ? any experiance with them?
Old 12-10-2004, 06:45 PM
Agip's Avatar
It is obviously a tunning issue, I presently running a conservative 485whp on stock sleeves b18c with Haltech no probs.
Old 12-10-2004, 08:19 PM
blackeg's Avatar
Default Re: (Agip)
im gonna pretty much say what everyone else has been. too much timing (or not enough retard) and the overbore combined to be the demise of your motor.
Old 12-10-2004, 10:16 PM
Default Re: (blackeg)
backing blackeg up, i used to have a stock b16 w/ the vafc hack, ran 112 octane all the time, never had any problems, so if i were to have detonation, i was kept to a minimal. It never had striaght up 93 so i wouldnt be much of help with it. it had a t3 on 8lbs so i never pushed it more than that.
Old 12-11-2004, 05:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
why GE ? any experiance with them? </TD></TR></TABLE>
A local preformance shop who builds engines only uses GE, and their engines make alot of power and last a long time. I perosnally dont know anyone who's run into trouble eaither.
Old 12-11-2004, 09:07 AM
same, AEBS is good too
Quick Reply: How much power can stock B18B sleeves handle, crack one last night @ 20 psi
