how to get into 13s
Old Oct 18, 2004 | 02:06 AM
1750cc's Avatar
Default how to get into 13s
i ran 14.5 - 14.6 on my ek sedan with b16a, its pretty stock, except for the b16b pistons and cams, toda cam gears, jdm type r headers with full exauhst 2.25", cold air intake, on advans ad07...
60ft = 2.3
et = 14.52
mph = 94.7
what other 'bolt-ons' can i get to lower my ETs? oversizing pistons is out of the question for me...vafc? bigger cams? type r intake manifold? budget is $1000 more or less...thanks
Old Oct 18, 2004 | 02:42 AM
Machine1's Avatar
Default Re: how to get into 13s (1600cc)
slicks.
Old Oct 18, 2004 | 02:56 AM
ExospeedAMcrx's Avatar
considering your budget. get CTR cams and slicks. that'll do it.
Old Oct 18, 2004 | 12:04 PM
Ress887's Avatar
Get a set of drag radials or slicks.
Or buy a good header (AN-R or somthing not mass produced like DC or Greddy)
Intake Manifold (skunk2, Type R (similar to sk2)
Maybe a set of cams, but then you'd want to tune them
Old Oct 18, 2004 | 12:51 PM
b16a2rida's Avatar
what cams are you using ? curious
Old Oct 18, 2004 | 03:53 PM
Gerhard_001's Avatar
Default Re: how to get into 13s (b16a2rida)
for everyone who is saying cams, you need to read the entire post thoroughly. B16B cams are Type R cams. There are actually some little tricks that you can do to your motor that are comletely stock and inexpensive, slicks are your best bet to lower your times.
Old Oct 18, 2004 | 03:55 PM
B16Civic93's Avatar
Default Re: how to get into 13s (Gerhard_001)
what little tricks can be done?
Old Oct 18, 2004 | 04:46 PM
hondaguyef's Avatar
Default Re: how to get into 13s (B16Civic93)
A 2.0 or lower 60' will get you into the 13's period! Get some Lenso's(13x7.5) and some M&H (22x8x13) slicks and you'll be there.
Phil
Old Oct 18, 2004 | 06:10 PM
b16turbokilla's Avatar
Get slicks and work on the 60' times
Old Oct 18, 2004 | 10:51 PM
1750cc's Avatar
garhard is right, b16b cams is TYPE R cams....yes i know its mild, but its good enough for me :D
im considering slicks...semi-slicks maybe, like formula-r or advan a032, but, wont it be a theat to my axles? ive heard that if the tires are too 'grippy' for the engine, i might break my axles...thanks. :D
Old Oct 19, 2004 | 01:44 AM
MAD SOHC's Avatar
Default Re: (1600cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1600cc &raquo;</TD></TR><TR><TD CLASS="quote">garhard is right, b16b cams is TYPE R cams....yes i know its mild, but its good enough for me :D
im considering slicks...semi-slicks maybe, like formula-r or advan a032, but, wont it be a theat to my axles? ive heard that if the tires are too 'grippy' for the engine, i might break my axles...thanks. :D</TD></TR></TABLE>
Go with full slicks the wheelhop caused from semi-slicks will be alot worse on your axles than actual slicks.
Old Oct 19, 2004 | 03:15 AM
hondaguyef's Avatar
Default Re: (MAD SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD SOHC &raquo;</TD></TR><TR><TD CLASS="quote">
Go with full slicks the wheelhop caused from semi-slicks will be alot worse on your axles than actual slicks.</TD></TR></TABLE>
I'll second that. I had the yokohama'a on my b16 hatch and it went 14.70's(wheelhoop like crazy). Then I got the BFG's and it went 14.40's (slight whelhop still). Then I got some 20x7x14 slicks and she went 13.90's. You can see the difference from tire to tire. Get slicks. D/R's are a waste (IMO of course)
00 Coupe EJ8
Mid-Atlantic (Sales)
Apr 27, 2011 08:12 PM
psegs80
K Series
Nov 25, 2009 08:27 AM
Teamdiesel
48
Jul 5, 2006 10:38 AM
shadowstylz
Jul 15, 2003 08:41 AM
Atiyeh
Jul 17, 2001 12:23 AM
