how do you work your alternators?
Old Oct 28, 2008 | 12:15 PM
turbociv910's Avatar
Default how do you work your alternators?
In my integra i have a motec harness, it does not have a provision for the alternator, i was told they are self regulating. meaning, i connected a battery wire to the alternator from the battery. I also have a race ati dampner, It will hang around 12 v, then creep down to 10.5 or so over running time. There is no plug pluged in the alternator.. is there a activation + or -?
Old Oct 28, 2008 | 12:24 PM
Turbo-charged's Avatar
Default Re: how do you work your alternators? (turbociv910)
you have to run 12v switch power to the plug that is usually built into the OEM engine harness. the alt wont work with out that.
my car is dead nuts rock solid at 14.3 volts the entire way down the track.
Old Oct 28, 2008 | 12:27 PM
vtekthis's Avatar
Default Re: how do you work your alternators? (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">you have to run 12v switch power to the plug that is usually built into the OEM engine harness. the alt wont work with out that.
my car is dead nuts rock solid at 14.3 volts the entire way down the track.</TD></TR></TABLE>
Old Oct 28, 2008 | 02:52 PM
may be a long shot, but which wire is it.
it may be low becuase of the twin a1000s and all my electronics, or is my alt just not tuning its self all the way on. When i unhook the wire form alt to battery, the car starts to die, when its on, it will idle, then slooooly start to die.
Old Oct 28, 2008 | 03:00 PM
tony1's Avatar
The small black/yellow wire on the alternator needs 12v when the key is on.
Old Oct 28, 2008 | 03:02 PM
Default Re: how do you work your alternators? (tony1)
then that allows it to be self regulating, or is that not a factor in this
Old Oct 28, 2008 | 03:06 PM
tony1's Avatar
Yes, the sw 12v wire powers the internal regulator.
the alt simply wont work with out it, and it will self regulate with it. go hook it up already lol
Old Oct 28, 2008 | 03:12 PM
5thgearburnout's Avatar
Tony, Cant you just run the black/yellow wire to the output/charge post of the alternator, then the alternator would start charging as soon as the engine turns over? It would essentially turn the stock alt. into a one wire alternator similar to a race unit? I was just thinking about this the other day and maybe I am totally wrong. Happened before
Old Oct 28, 2008 | 03:52 PM
Drag_S14's Avatar
Default Re: how do you work your alternators? (5thgearburnout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgearburnout &raquo;</TD></TR><TR><TD CLASS="quote">Tony, Cant you just run the black/yellow wire to the output/charge post of the alternator, then the alternator would start charging as soon as the engine turns over? It would essentially turn the stock alt. into a one wire alternator similar to a race unit? I was just thinking about this the other day and maybe I am totally wrong. Happened before </TD></TR></TABLE>
I tried originally doing this, but it ends up just draining the battery, since the regulator is always on whether or not it is turning. Better option is to wire it to key on, or use an output from your EMS of choice to turn the alternator on over a few hundred rpm. I have mine set to turn on at 400rpm, that way it doesn't load the engine down during cranking.
Old Oct 28, 2008 | 06:34 PM
Default Re: how do you work your alternators? (Drag_S14)
it worked, only to find out i spun a bearing on cyclinder one... less than 20 min run time
Old Oct 28, 2008 | 07:27 PM
tony1's Avatar
How'd you manage that?
Old Oct 28, 2008 | 07:33 PM
rota92
Guest
Posts: n/a
Wow! Motec on the Daily? BLING!
Old Oct 29, 2008 | 06:31 PM
un reliable engine builder.
only thing that is salvage able is the benson sleeves.
yes i have motec on both of my cars. I use the same one, i rarely drive the "race" car, and when i do, i just load the correct map.
Fireman Jim
Dec 30, 2012 10:38 PM
pr0honda
Oct 21, 2009 09:22 AM
BlueShadow
Aug 2, 2004 12:36 PM
Robb
Aug 7, 2002 06:38 AM
