launch rpm?
Old Oct 26, 2008 | 10:45 PM
99Geeezer's Avatar
Default launch rpm?
hey guys. Just curious what rpm do you launch at when on the drag strip? I m going to the track for the first time so just wanted some advise. I have a mildly built b18c1 with forge wiseco pistons and type r cams. My clutch is a comp clutch st2 with lightened flywheel but OEM axles. I just don't want to break anything. Any advise would super cool. Thanks
Old Oct 26, 2008 | 11:53 PM
blacK_Dc4's Avatar
Default Re: launch rpm? (99Geeezer)
Try the Drag Racing forum. It would also help alot if u include what kind of tires you're using , what chassis the motors in , what kind of power your motor is making , and which tranny you're using. Launch RPMs can vary alot
Old Oct 27, 2008 | 03:26 AM
00b20vtecoupe's Avatar
Default Re: launch rpm? (blacK_Dc4)
ide say depending on the car and tires anything in vtec around 6000 to 7500. i think everyone is dif.
Old Oct 27, 2008 | 09:11 AM
RedneckRicer's Avatar
trial and error find out what you and your car likes. i know my car likes to be launched at 6800. when i drive my friends car it likes to be launched at 5600. every car is different.
Old Oct 27, 2008 | 09:31 AM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 &raquo;</TD></TR><TR><TD CLASS="quote">It would also help alot if u include what kind of tires you're using , what chassis the motors in , what kind of power your motor is making , and which tranny you're using. Launch RPMs can vary alot</TD></TR></TABLE>
Agreed... Let us know what setup, etc...
Old Oct 27, 2008 | 10:45 AM
99Geeezer's Avatar
Default Re: launch rpm? (ALLMOTOR18)
The car is a dc2. I will be running my street tires which are toyo proxes on 16s. not too sure what kind of power the motor makes but i have a base map from phearable. my gearbox is a gsr tranny with a typr r lsd. my valve train is good and the motor is beefed up with rods and pistons(eagle rods/12:1 comp). i know it will be trial and error but just wanted some insight before i hit the tarmac. i'm sure i'll have wheel spin. should i drop my tire pressure? thanks guys. keep the advise coming.
Modified by 99Geeezer at 12:11 PM 10/27/2008
Old Oct 28, 2008 | 03:29 AM
oldskool teggy's Avatar
if you are on proxes, slip the clutch.. those tires have a tendency to hop like crazy if you are not careful.. oon street tires, i'd say nothing less than 20 psi
my recommendation would be to get some drag radials.. your 1-2 gears are gonna go up in smoke with more than 280 whp on tap
Old Oct 28, 2008 | 07:29 AM
blacK_Dc4's Avatar
which proxes ? .. the T1R ? , if so id say start at around 4,000 rpm and trial and error from then on. I launched at around 3800 on Kuhmo SPTs on my Dc2 with the 2.0L setup and the R tranny . PSI was at around 23 psi.
Old Oct 28, 2008 | 03:57 PM
Drag_S14's Avatar
950rpm.
Old Oct 29, 2008 | 08:43 PM
srmofo's Avatar
Default Re: launch rpm? (Drag_S14)
^^^its funny cause its true...street tires wtf you go anyhigher than 3k and your 60 fts are gonna be in the 3s
Old Oct 29, 2008 | 09:43 PM
Drag_S14's Avatar
Default Re: launch rpm? (srmofo)
Hell, I'll be launching at 3500rpm in my race car on 28's...
Then again, I'll also be spraying 150+ to it too
01em2turboex
Honda Civic (2001 - 2005)
35
Jul 21, 2008 10:38 AM
FlatlineSI28
Dec 16, 2007 07:52 PM
4Dinsaneb16
15
May 10, 2007 06:33 PM
Ray-mond
May 4, 2006 07:37 PM
zero2815
Dec 11, 2003 03:36 PM
