Hondata COP
Old May 7, 2011 | 11:26 PM
96civic cr-v's Avatar
Icon2 Hondata COP
Is anyone running there new coil on plug set up? Would like to see how it compares to other COP set ups.
Old May 8, 2011 | 07:23 AM
SPOOLINmatt's Avatar
Default Re: Hondata COP
its not being distributed yet as far as i know.
Old May 8, 2011 | 08:52 AM
96 GSR-T's Avatar
I dont see how it can compare to a true direct fire COP powered by an ignition box
Old May 8, 2011 | 09:15 AM
twkdCD595's Avatar
It is only pre-order right now by some distributors from what I have seen. Release date is said to be June sometime on their sites.
I think it will be interesting to see the results, curious to see how far it takes people without needing to be amplified. Although as said above not sure it can be really a fair comparison to other COP systems out since they are amplified.
Still I would be interested to see how it performs even though I personally went the route of a PRO10 kit from t1.
Old May 8, 2011 | 09:31 AM
the site says it works with aftermarket CDI Boxes.
Old May 8, 2011 | 09:38 AM
tony1's Avatar
It just gives you four outputs, can run a CDI or inductive system with it.
Old May 8, 2011 | 10:38 AM
96 GSR-T's Avatar
Didnt know that, but your still stuck with getting the signal from the oem dizzy right?
Old May 8, 2011 | 11:59 AM
Turbo-charged's Avatar
Yup
Old May 8, 2011 | 02:50 PM
01DC4's Avatar
Whats wrong with that? Thats all your using it for is the signal.
Old May 9, 2011 | 03:08 AM
E Town DSM's Avatar
Because usually the signal is the issue.
Old May 9, 2011 | 11:31 AM
Bsracing78's Avatar
in my limited experience 99% of honda distributor failures are coil, igniter, or secondary ignition componants. i have seen very few sensor failure's in the stock distributor. therefore the hondata COP setup would eliminate 99% of stock distributor ignition problems. in theory lol.
Old May 9, 2011 | 12:03 PM
BioXide02's Avatar
Me too - I am in the market for an Ign setup now and I am not sure what to go with Pro10 kit or this new hondata product.
Old May 9, 2011 | 12:14 PM
Garage 808 Hatch's Avatar
M&W, dont have to wait at least a month for it to be released
Old May 9, 2011 | 01:56 PM
AllShowNoGo727's Avatar
cant wait for this to come out.
Old May 9, 2011 | 03:40 PM
xenocron's Avatar
Because there is no real way to "log" the signal...so you arent really sure what its doing all of the time. With a good aftermarket ECU, you can count every cam, crank or TDC pulse (if you even need all of those for your application) whereas the Honda ECU does a lot of stuff we really dont have access to.
There is nothing WRONG with it realistically, but if you need to be exact...then this is where the short comings of the factory dizzy and ECU come out.
Old May 10, 2011 | 06:12 AM
nos51's Avatar
i think its going to work great,we run stock k series coils making 1000+ with no misfires im really excitied about this new option for the b series guys
Old May 10, 2011 | 08:03 AM
sp00led's Avatar
I'm running a .024" gap and not misfiring at 550whp (25psi). Would anyone care to speculate that running a hondata COP would benefit a mild setup like mine or are these generally for big HP cars that have issues blowing out spark?
Old May 10, 2011 | 08:37 AM
locash's Avatar
You may not see it in the power numbers at that level, but you will benefit from better coil charge time and better spark distribution. By eliminating the stock coil, ignitor, cap, and rotor, you are eliminating a large amount of the problems associated with the stock ignition system.
guy_from_nerk
Engine Management and Tuning
20
Oct 24, 2012 06:34 PM
MilanoEj1
33
Nov 3, 2010 05:41 PM
g0tgot
Nov 23, 2008 02:14 AM
'98VTEC
Nov 17, 2007 08:54 PM
RMS
Feb 1, 2004 07:07 PM
